Loading paper and original documents
1. Make sure:
• You use paper designed for inkjet printers.
If you are using photo, glossy, or heavyweight matte paper, you load it
with the glossy or printable side facing you. (If you are not sure
which side is the printable side, see the instructions that came with
the paper.)
• The paper is not used or damaged.
• If you are using specialty paper, you follow the instructions that came with it.
• You do not force paper into the printer.
2. Before loading paper the first time, slide the paper guides out toward the edges of the paper support.
3.
Load the paper vertically in the center of the paper support, and
adjust the paper guides to rest against the edges of the paper.
Align the print cartridges
In Windows
To clean the print cartridge nozzles:
- in Windows Vista, click .
- in Windows XP and earlier, click Start.
In Windows
- un Windows XP and earlier, click Start.
