Panasonic RR-930 Desktop Cassette Transcriber / Recorder Logo
Posted on Oct 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change the drive belt? - Panasonic RR-930 Desktop Cassette Transcriber / Recorder
Dictation Mall
Level 2:
  • Expert 145 Answers
  • Posted on Oct 30, 2010
Dictation Mall
Expert
Level 2:
Answers
145
Questions
0
Helped
54595
Points
173
This is not an easy task on this model. First make sure you remove the power cord as you can easially receive a deadly shock. You have to remove 5 case screws, then the deck screws, then 2 pc board screws, 1 which is hidden in the slide control assembly. Remove the button assembly. You need to get the complete assembly out working around cables, and the solenoid lever. Then there is a screw on the bottom of the circuit board to the deck that needs to be removed. Now you can get to the belt. Replacing the belt on this model requires a high level of expertise and is not reccomended for the inexperienced technical person.
2answers
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
I need a belt diagram for a Mercury Grand Marquis 4.6L V8 engine 2006
SECTION 303-05: Accessory Drive 2006 Crown Victoria/Grand Marquis Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 03/18/2008 Accessory Drive adobe.gif Printable View (104 KB) The accessory drive system:
  • has a single serpentine accessory drive belt with 6 ribs.
  • has an idler pulley.
  • has an automatic drive belt tensioner.
  • is not adjustable.
The accessory drive system provides power to operate components which power other systems. These could include components such as the generator, power steering pump and A/C compressor. Each of these components is equipped with a pulley which is driven by the accessory drive belt. The accessory drive belt is driven by the engine crankshaft pulley. One or more idler pulleys may be provided to facilitate belt routing and alignment. The automatic belt tensioner maintains correct belt tension and compensates for component wear and changes in system load. System load changes can be caused by the A/C compressor clutch engaging or disengaging, or demand changes on other systems powered by the accessory drive belt. To maintain correct operation of this system, it is critical that the correct length drive belt be installed. The pulleys must also be correctly aligned and kept clean.
Accessory Drive Belt Routing
Item Part Number Description 1 8678 Accessory drive belt idler pulley 2 10344 Generator pulley 3 8620 Accessory drive belt 4 3A733 Power steering pump pulley 5 6312 Crankshaft pulley 6 8509 Coolant pump pulley 7 2E884 A/C clutch pulley 8 6B209 Accessory drive belt tensioner pulley Belt Tensioner
Automatic tensioners are calibrated to provide the correct amount of tension to the belt for a given accessory drive system. Unless a spring or damping band within the tensioner assembly breaks, or some other mechanical part of the tensioner fails, there is no need to check the tensioner for correct tension.
2010&c18=modelyear&c20=n924137&c35=wsm%2caccessory%20drive%2cs6a%2c303-05%2cdescription%20and%20operation&s=1249x702&c=32&j=1.3&v=y&k=y&bw=910&bh=359&ct=lan&hp=n&[aqe]
2helpful
3answers
My daughter has a 2004 Kia Optima with 82k miles. I don't believe the drive belt has ever been replaced. Is it overdue?
Are you talking about the accessory drive belt or the ignition timing belt?
In any event, if you're confident it is the original, then by all means replace it.
My point in asking about which belt has to do with difficulty of repair. You should be able to replace the accessory drive belt yourself, but you should consider having a mechanic do the ignition timing belt.
Good luck
1helpful
Drive Belt broke on my 2005 1200XLC Sportster
A Sportster is not too difficult to change. You will have to remove the rear wheel, the right shock absorber and the front drive sprocket cover to change the belt. I think you can get the belt on without pulling the front drive sprocket. I always pull it but I don't think it's really necessary. You can work the belt over the edge of the sprocket.
When you put the new belt on, put the right leg of the swingarm through the belt so that when you get the belt over the front drive sprocket, the other end of the belt is INSIDE the swingarm. Take care and do not bend the belt into a radius smaller than about 4". Bending it any smaller than that will break the fibers in the belt and shorten the life. They ain't cheap either. There should be a note in the box about this. If you must take the front drive pulley off, an air wrench will usually do the trick.
The BIG TWINS are the ones that are a real PITA.
Good Luck
Steve
How to change 1999 nussan quest ac belt
http://groups.yahoo.com/group/villagerquest/
Belt —A/C Removal
  1. Remove the A/C compressor drive belt.
    1. Loosen the A/C compressor drive belt pulley tensioner bolt.
    1. Loosen the A/C compressor drive belt idler pulley adjustment bolt.
40f6b66.gifInstallation
  1. sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Incorrect drive belt installation will cause drive belt failure.
    NOTE: Inspect the pulleys for warping or abnormal wear.
    NOTE: Make sure drive belt is properly installed on each pulley.
    To install, reverse the removal procedure.
    • Adjust the A/C compressor drive belt. For additional information, refer to Belt Adjustment—A/C .
Periodicity for the change of the drive belt
the drive belt should be changed when it has visable signs of cracks or damage, or i like to change them every three years,and keep the old belt in the back of the car for a spare in case something happens.
2helpful
How to change engine belts on a jaguar x-type 2003 3.0
To Remove BELTS : Drive Belt :
Disconnect battery ground cable
Remove wheel and tire
Detach accessory drive belt
detention drive belt
detach accessory drive belt
Remove accessory drive belt
slacken the tensioner
remove accessory belt drive
Install in reverse order
WATER PUMP BELT : Remove battery tray
Remove water pump belt
De-tension water pump belt
Installation in reverse
Hope this is helpfull
1helpful
Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
1helpful
Changing the belt
flip over
remove 3 phillips head screws and remove cover
pull agitator roller out of groove opposite end of drive belt area
install new belt by putting loop around silver drive shaft then putting over belt roller
put roller in appropriate grooves( belt will feel stiff make sure belt stays on roller and under drive shaft put cover back on
You are ready to go!
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
