Here's my shortcut:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Here is a suggestion from the iRiver website - you may want to visit that website, b/c their "Ask Alice" tech support feature is actually quite good:
The players come with a CD that contains drivers and software that
enable the player to download data from a PC. Insert the CD in the
computer's CD drive, and connect the player to the PC with the USB
cable. (
Help with USB cable connections) The
PC should automatically detect the device. The New Hardware
Installation Wizard will automatically launch and the installation
process will start.
If the above procedure does not occur on your PC, please manually install the driver. Use the links below for instructions:
If
you still have trouble, the issue may be with the computer chipset.
iriver has tested many PCs and discovered that this only occurs in a
small number of main boards.
Recently i have bought a 4gb ipod & it was working at first.After some days i can copy only 104mb of data to it.Idecided to change the firmware & upgraded it to another firmware found on the net.Now the ipod is totally dead & when connected to my pc it detectes the same asUSB 2.0(HS) ADFU Device &opens hardware installation wizard & asks for adfu files(driver).Friends i really don't know what to do.pls help me.Thank u all.....
Recently i have bought a 1gb Chinese ipod & it was working at first.As some problem cropped up in navigation of the menus, I decided to change the firmware & upgraded it to another firmware found on the net. Now the ipod is dead & when connected to my pc it detectes the same asUSB 2.0(HS) ADFU Device &opens hardware installation wizard & asks for adfu files(driver).The MP4 player is not being recognised as a removable drive in my PC
chinese ipod showing no response after being switched on.
mi mp4 prende y todo pero la computadora no muestra carpetas, ni lo detecta
I am using my mp3 player and suddenly it gets a blank screem and it doesnt work anymore bot when I connect it to my pc, I can see the content on it....So anyone do you know what happend?
please give name of Operating system and version (eg Win 2000 SP4). Have you tried it on any other machines?
I have Sony 8GB 4.3 touch HD player. Usb won't connet to computer. I reset and now froze on Sony Walkman cover.new device attached to your computer, but could not find the driver software it needs to make the device usable. The hardware ID of your device is USB\VID_10D6&PID_FF00&REV_0100
OS Version:6.0.6002.2.2.0.768.3
Please HELP, Brenda
