Description:The main thermistor (TH1) has poor contact or an open circuit. The thermal switch (TP1) has an open circuit. The fixing heater has an open circuit. The AC driver is faulty. The DC controller PCB is faulty.
After the main power switch is turned on, the temperature detected by the main thermistor does not reach 70°C.
The error must be reset in service mode (COPIER>FUNCTION> CLEAR>ERR).
Canon Printer Error 5200 may occur if the ink level in your printer is low or if you have a defective ink cartridge. Follow the steps to fix Canon printer 5200 Error code:
·Refill your cartridges/Ink tank ·Clean printer cartridge ·Factory reset printer
2. This error code generally occurs when printer is not connected to the computer. Many printer connectivity issues arise due to loose cable; make sure all the ...
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can... Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041. To clear the error: * 2 8 * COPIER FUNCTION CLEAR ERR OK Turn off and on ( main switch )
