Anonymous Posted on Jun 10, 2008
No output to speakers mackie 808s power mixer
Mixer section seems to be working have mixer light action with input but no output to speaker no blown tops on transistors or ic no obvious burnt resistors or diodes no obvious short on transistors or diodes without schematic hate to go much further ..any pica fuses or such that may be blown? any known issues with power transformer? thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 17, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1106
Points
I can hardly even tell what you're talking about because you don't use any punctuation.
Mixer signals is on but qsc 1450 amp not giving any sound when main output is connected but when run aux send to amp it gives sound. What might be the problem.
If you are experiencing an issue where the QSC RMX 1450 amplifier is not giving any sound when connected to the main output of your Mackie 16 OK mixer, but works when connected to the aux send, here are some possible causes and solutions:
  1. Check the main output level on the Mackie mixer. If the level is too low or muted, this can cause the amplifier to not produce any sound. Increase the main output level on the mixer and check if the amplifier produces sound.
  2. Check the cables connecting the mixer to the amplifier. If the cables are damaged or not connected properly, this can cause the amplifier to not produce any sound. Ensure that the cables are connected securely and are not damaged or broken.
  3. Check the amplifier settings. Ensure that the amplifier is set to the correct input source and that the input gain level is set correctly. You may also want to check if there are any protection modes or limiters enabled on the amplifier.
  4. Check the speaker connections. If the speakers are not connected properly or are damaged, this can cause the amplifier to not produce any sound. Ensure that the speakers are connected correctly and are not damaged.
  5. If none of the above steps work, there may be an issue with the mixer or the amplifier. You may need to contact a qualified technician to further diagnose and repair the problem.
Remember to always follow the manufacturer's instructions and safety guidelines when working with audio equipmen
1helpful
With the Mackie PPM608 Mixer, our passive speakers aren't working. We use CVi-252s, but I'm sure it's an issue with the mixer rather than the speakers.
Get a plug cable and work the plug in and out of all INSERT or BYPASS jacks. These get rusty and interrupt signals.
If that is a no, open up and check power supply voltages and all cable connectors, might have been vibration and something got loose...
PEACE---
How to connect Mackie Mixer 1402vlz4 to Bose Accoustimass 5 speaker
you need a power amplifier between the mixer and the speakers to actually drive the speakers. You would have to choose which amp to use (the manual, found here: http://www.bose.ca/controller?url=/shop_online/speakers/stereo_speakers/acoustimass_5/index.jsp#manuals suggests between 10-200 WRMS for power), and thus would have to determine the cabling options depending on the amp you choose, but...go from either the MAIN or CONTROL ROOM outputs of the Mackie mixer into the inputs of the power amp. Then go from the outputs of the power amp to the inputs on the Acoustimass bass module, which also runs the Acoustimass satellite speakers.
Apr 17, 2014 • Music
I have a mackie fx 8 mixer connected to two thump 15 " speakers. i want to add a set of base non- powered speakers with power amp to my fx 8. what are the connections?
Balanced audio interconnects (either XLR or TRS cables from the mixer and then balanced audio interconnects from the amp daisy chain inputs to the existing speaker inputs. If the amps do not have linked input jacks, then use TRS type WYE connectors at the inputs. Then use speaker rated cables from the amps to the passive speakers.
1helpful
Wish to run sm450v2 Mackie powered speakers thru a Peavey XR8600
The Peavey XR8600 is NOT just an amp, but a powered mixer.
To SAFELY use this with your powered speakers, connect those speakers to the MAIN and MONITOR outputs on the front of the unit with 1/4 inch INSTRUMENT rated cables (NOT speaker cables).
To safely leave the power amps in the XR8600 with no output loads, plug GROUNDING plugs into the POWER AMP 1 and 2 input jacks on the front. This will prevent the power amps in the XR8600 from running with no load which COULD damage them.
Make the grounding plugs from 1/4 inch mono plugs by jumpering the centr aand sleeve terminals of the plug.
Karaoke, plenty vocals in floor ,no music without loud humming
Try a couple things
Try plugging the player directly into one of the stereo channels using correct cables (just go to Radio Shack or someplace like that) - you'll probably have to get a stereo to mono "Y" adapter that terminates in two mono mini or 1/4 inch male jacks ... if mini, then upsize them with another adapter ... it's not as rigged as it "sounds" ...
The benefit is, it is actually simpler and you will be able to use all of the channel strip controls for the player just as you would for a mic or guitar plugged in to a channel, and the volumes will behave more as you expect them to ...
Just be absolutely sure the cable you assemble is correct, meaning stereo single 1/4" (or whatever it is, two RCA's whatever) going into the player, and terminating on the other end with two MONO 1/4 inch jacks ...
I use this kind of "Y" connector to play my iPhone through my 808s and it works very well, and I have full control and no confusion.
I'm not sure what you mean by running your player through the "aux in" on the front of the 808s - there are different versions of this mixer, but mine doesn't have anything labeled "aux in" - if you mean the tape inputs on the right front ... RCA jacks ... that should also work, but I prefer just using the normal input channels ...
For example, use input 8 - it's labeled "mic 8" - but if you use the two 1/4" jacks above the Canon jack the mixer will automatically adjust to line level ... on my 808s these 1/4" jacks say "stereo mic/line" ...
Also, I would bypass the effects section completely unless you need it and understand how it works ... and
Make sure the "Power Amp Routing" switch is in the correct position ... since you are using mains and monitors you probably want the "mono" position, which disables the stereo outputs and instead uses one of the power amps for the mains and the other for the monitors ... on my 808s this is the "in" position
On the back, you'll use the speaker outputs labeled "left/main" to go to the main speakers and "right/monitor" to go to the monitor speakers
It's actually pretty simple - with the Power Amp Routing switch pushed in, you no longer have stereo, so ignore "left and right" on those speaker outputs, and follow the labels for "main" and "monitor" .....
Hope that helps!
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
1helpful
3answers
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
1helpful
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
2helpful
Leem m86t power mixer amplifier
probably blew the amps or the pre amp section
3answers
Sub will not power.
I reckon there is a good chance you've got a dodgy mains transformer, or perhaps a blown internal fuse. Sounds very much like the problem is on the AC input board.
 Grubhead
Grubhead
SmartAviator
SmartAviator
