1st You download Webcam Driver.
I cannot uninstall livecam vx-3000 cause
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
SOURCE: Lifecam VX-3000 - Installs then says not there
you have to go in your preferences, then to connection, in yahoo and set it to no proxies, then in the drop down menus pick your internet connection and your home country, it should work on yahoo after that.
SOURCE: LifeCam VX-3000 Audio Problems
Audio Setup needs checking. Here is info that might help.
Normal 0
Web Camera’s have to be setup on the program they areto be used with. Just installing thecamera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
The camera and audio should function properly. Your friends and Family will now see andtalk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger setit up as follows:
When done both the Audio and Video will function properly soyou can chat and see family or friends you are connected to.
Hope this helps. Bud
SOURCE: need to download microsoft livecam
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
From the link above
1. Select type of product [webcams]
2. Select your product [LifeCam VX-3000]
3. Select your operating system
4. Selectyour operating system language
Here you go!
SOURCE: Installed VX-3000 software on XP SP2 PC. PC
go in system set up and then look for boot device configuration and change the option 'boot other device' to no boot and save and exit
SOURCE: TRIED MICROSOFT DOWNLOAD FOR LIVECAM VX 6000 AND
go to microsoft
Make sure your downloading the software that is correct for you Operating System.
32 bit or 64 bit XP or Vista Etc
