My samsung rant wont charge no more it seems every charger i put for my cell phone wont charge it i bought a new charger and battery the new battery turns on the phone but the cellphone wont charge still and its the inside of the cellphone that wont let you charge it
my friend has an s2 she bought a new battery and charger and it still wont chargemy friend has an s2 she bought a new battery and charger and it still wont charge
You can't post conmments that contain an email address.
Phone not charging. Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
I had a similar problem when I was using my computer cable for convenience. I asked my stepdad, since he's an very computer smart and he told me the computer cord is not for charging and when I switched back to the wall charger it was fine. You'll just have to go buy a wall charger.
there are 2 possible reasons for the problem u mentioned..
either ur phone charger port or its internal connection is defected
or ur charger circuit or wire orits pin is the problem
you can find it by connecting ur phone with system using usb data cable..if it charges then ur charger kit is to replaced..else u must service ur phone
This worked for me........Plug in the charger, and then wrap the cord around the phone tightly! But no too tight or the whole damn thing will fly out (this happened to me)
Hey guys, i'm sorry but i have some bad news :(
This black screen of death which you have all been experienceing has been a problem of many different phones and all of them have the same cause. It is a manufacturer defect in the phone which pretty much has screwed up the software inside. Sometimes it may take a while for this problem to be come apparent (such as in my case it took nearly a month). I have done hours of research, and there was only one solution. The phone needs to be replaced.
Sprint has told me that no customer will be charged for replacing the phone (insurance or not) because it is a manufacturer / software problem. the only difficulty is that without phone insurance, it may take a few weeks to get your new phone sent to you from Sprint. With insurance, you can just walk into a Service center and get ur phone replaced on the spot.
One major pain with this problem is that all phone numbers and data (except on the mini sd card) is erased or unreachable.
Sorry about the bad news, but i hope this helps everybody getting this same problem no matter what the phone.
--Gleo--
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
1. get it repaired, under warranty if possible 2. Get a new one 3.Get
an external battery charger and charge battery separate from
phone.Another battery and charger will set you back about 10 dollars on
ebay
