Canon PIXMA MP760 All-In-One InkJet Printer Logo
Posted on Oct 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer isn't printing and has a error message that states "the type of print head is not correct. install the correct print head"". This printer was printing last night. what can I do?
Level 3:
  • Canon Master 7,733 Answers
  • Posted on Oct 28, 2010
Canon Master
Level 3:
Answers
7733
Questions
0
Helped
1863844
Points
21487
Why my printer mp610 shows code U052, what does it mean?
The U052 printer Error occurs in two different scenarios. The First one is when the print head is not installed properly on the canon printer. And the second Scenario is When the print head is installed well but is not working properly.
Follow the steps to fix the U052 printer error code. Need any type of help contact printer experts through Free Live chat.
My Pixma 500 printer now gives me an error stating that the wrong printer head is installed. The printer head has not been changed nor tampered with.
Canon printer is also one of them and can give you issue such as Canon printer in an error state.
A number of people who use Canon printers in their daily work may encounter a printer error that is "Canon Printer Error State". Also, they often seek help to fix this frustrating issue. The printing process is blocked by a system issue, prompting the Printer is in Error State error message. To get your printer out of the error state, the first solution is to change the ports settings.
This step-by-step guide, you will understand how to repair Canon Printer Error State.
Steps that fix Canon Printer Error State:-
Step 1: Correct Port issues.
Step 2: Re-install the driver.
Step 3: Manually update the driver.
Contact Expert here - Canon Printer Error State
I have a canon pixma610 printer scanner. it gives an error message 'print head is incorrect "uo52"
The data connection between the processor of the printer and its printing head is flawed. This can be caused either by a bad connection (the head is badly installed in its carrier) or by a failure of the processor.
Try reseating the head - if the situation isn't fixed then the processor has failed. In that case the printer is dead, time for a new one.
When I try to print the message I get "The type of print head is incorrect. Install the correct print head." I have had the printer for some time and have never had a problem before.
Sometimes such errors can pop up when there are errors in the driver software so in most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Message on printer says "The
The HP D145 uses a special print head cartridge for each ink cartridge. They are not interchangeable.
1helpful
Error message - appropriate print head not installed - what do i do
Pixma MP760 error is showing on printer: The type of print head is not correct. Install the correct print head. I unplugged the printer for a few minutes. Didn't help. The same error window shows up when I try to print from computor. When I open the printer to look at the cartridges they do not come out to the middle.
Re: Canon pIXMA MP830 printer: Error message on printer screen reads: "The type of print head is incorrect. Install the correct print head". I lost the "easy set up page: Bill...
Hi
I think you need to check if the inkjet (print head/ Cartouch) is installed ok on the printer.
& Make sure it is the type supported by your printer.
I hope this was your problem.
old marine
old marine
ZJ Limited
ZJ Limited
