Running triple channel memory with more than 3 DDR3 1600 sticks installed (4-6) cuts the memory speed in half. you have to run with 3 sticks at a time in triple channel mode or you will see a reduction in ram speeds.
OCZ is making some good 4 gig ram sticks. they have a 12 gig triple channel memory kit with 3x4gig sticks. you could get 2 of these kits and have your 6 sticks- 24 gigs total, but your memory frequencies will be lower- your ram access will be slower.
If you are referring to computer RAM always put the largest ram module closest the CPU central processing unit
try to keep the same brand and type of ram the same ie: ddr ddr3.......
you will be able to read the ram type on the ram already inside
make sure you secure the ram modules by pressing the levers down firmly at both ends of of there sockets
make sure your computer is turned of before you attempt this
be sure to wear an earth strap before touching anything inside your computer
the ram modules sockets are located near your cpu
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope this helps you
