GE Monogram ZE2160SF Convection / Microwave Oven Logo
Posted on Oct 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Light goes on, turntable rotates, time on displays counts down as per setting -- but no cooking. Nature of problem??
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Oct 27, 2010
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2734260
Points
22413
If everything works, but the microwave oven does not heat, this is most commonly caused by a failed magnetron. The magnetron is essentially, the heart of the oven that produces the RF energy that is used to heat your food. In order to replace a defective magnetron, you will need to consider the following:
1. You will need to uninstall the oven from over the range in order to replace the part (you will need to do this anyway, if you decide to buy a replacement oven).
2. Ensure the oven is UNPLUGGED before servicing anything inside the cabinet and remove the exterior case in order to access the magnetron.
There are several websites that you can use that illustrate how the oven is assembled:
searspartsdirect.com pcappliancerepair.com appliancepartspros.com
NOTE: If you've never repaired an appliance on your own before, a microwave oven is usually not a recommended appliance to start with. Some models can be rather involved in taking apart.
If the model number you posted this question under is correct, the magnetron replacement part number is WB27X10682. NOTE: This model also has two internal thermostats that, if tripped, could give you the same symptoms. The thermostat acts as a fuse if the oven cavity or magnetron overheats. The part numbers are as follows: Cavity Thermostat: WB27X10683 Magnetron Thermostat: WB27X10567 You will need to remove the thermostat from the oven and take a resistance check across the component terminals to determine if it is good or not. A low resistance reading indicates a good thermostat. An infinite reading, indicates a blown thermostat and needs to be replaced.
I would recommend you check both thermostats, first as the replacement cost is much less than the magnetron.
Review the parts illustrations at the recommended websites to see if this is something that you may be able easily take apart and reassemble.
If you have any questions, please post back and let me know. I hope you find this information helpful.
CAUTION: DO NOT operate a microwave oven with the exterior cover off. The voltage inside the High Voltage network where the magnetron is installed can exceed 3,000 volts!
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
2answers
The motor will not work. The interior light comes on, but the turntable does not go around. The cook time counts down, but no cooking occurs.
the turn table motor could have failed, but the counting down will be the monitor switch or a micro switch located behind control panel
3helpful
2answers
My microwave is completely dead. I have checked the fuse in the plug and it is fine. Any suggestions?
What you are to do to solve the problem is to do a general troubleshooting on your oven below are instruction to follow.
The Microwave is a counter top model with a variety of preset cooking options, including timed cooking at a variety of power levels and sensor-cooking settings for popcorn, rice, beverages and single-serving reheating.
The sensor cooking and reheating features detect increasing humidity levels inside the microwave and automatically adjust cooking time for various types and amounts of food. This microwave also includes a turntable and an electronic control panel.
Instructions below are step by step solution for your oven
  1. Check to see if the microwave will start. If it will not start and the display panel is blank, you may have a power problem. Unplug the microwave and then plug it back in, making sure that all three prongs of the power cord are fully inserted into the wall outlet. If this doesn't work, check your home's fuse box. Reset the circuit breaker to restore if necessary.
  2. Ensure that the microwave door is fully closed. Press the Clear/Off button to cancel any previous cooking instructions. Re-enter your cooking program, including cooking time and food weight if necessary, and press Start.
  3. If "Err" appears on the microwave display, press the Clear/Off button and reenter your cooking program. The "Err" message will appear during the sensor-controlled programs (Popcorn, Rice, Beverage or Reheat) if the door is opened before steam is detected or if no steam was detected within the maximum amount of time allowed by the microwave. Be sure to leave the door closed during these programs, at least until time is shown counting down on the display panel.
  4. If your control panel will not work or if an "L" is displayed on the screen, press and hold the Clear/Off button for a full three seconds to unlock the control panel.
  5. If your sensor reheat program is resulting in under- or overcooked food, first try decreasing the amount of food in the microwave; the sensor programs are designed for single servings of food. The sensor reheat function works by measuring humidity inside the microwave--do not use a tightly-covered dish with this setting because no moisture will be able to escape and the food will overcook. Be sure that cooking containers are dry; moist containers will increase the humidity in the microwave and mislead the sensor, resulting in undercooked food.
  6. If your turntable is not rotating, first check to ensure that your food container is positioned so that it can freely rotate without hitting the microwave's interior walls; using a smaller food container can fix this problem. If the turntable still will not rotate, lift the turntable from its support and replace it carefully, ensuring that it rests evenly on its support.
Good luck.
Thank you and thanks for using fixya.
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Set control board to cook and not working
you have a bad door switch, check for burns on the switches and connectors, if not its the pc board
Microwave runs but does not heat food either with sensor or manual timing. Occasionall will displasy 'SENSOR ERROR'. Have closed door and pressed CLEAR/OFF per manual instructions, but still does not...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
INFO: On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
If the reset didn't fix it:
When you hit Start to cook, do the inside light and turntable come on?
Any unusual noises?
Is it louder or quieter than usual?
Do you have the model number?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
1helpful
Nnt553w panasonic microwave. Whilst heating something he oven stopped and the display said refer to operating instructions. Now seems to be working but doesn't heat.
When you enter the time and press Start:
Does the inside light come on?
Does the turntable rotate?
Do you hear the internal cooling fan running?
Does the time count down?
Combination microwave oven
What is the nature of the failure?
Can you enter cooking the time?
If so, what happens when you press Start?
Does it run (count down, lights on, turntable on ) but not heat?
Brand and model might help, too, but the basics are the same, so we're happy to help you with more information.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
