IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The
only button on your stove that should make the door lock would be the
clean button (self clean model) if that is pressed simply hit the
clear/off or cancel key and wait for the door to unlock.
IF the self
clean option ran for an hour or so, you will have to wait for the oven
to cool down before the lock can unlock (safety feature).
These codes mean that the oven's electronic control has detected a
condition it needs to check. When you see a code, follow these steps:
hope this help?
Thanks for using fixay
