It's normal for that light to not come on. If you have tried two different remotes, and new batteries then this confirms that the actual I/R receiver on the player has failed. It is fairly common for this to happen actually. Unfortunately no remote will work with this player in that case. It is possible to replace the I/R receiver but it is very difficult to do yourself, and expensive to have done. At that point you would be much better off just replacing the whole device.
So sorry about that, but it definitely sounds like your infared port has failed.
Thanks
Tim
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Thanks a lot Tim. I was told before I ordered the new remote that it was a possibility. I had forgotten. Darn. Oh well Christmas is coming. Thanks again.
