If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive. The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction. To enable fax confirmation from the control panel 1. Press Setup. 2. Press 2, and then press 3. This selects Print Report and then selects Fax Confirmation. 3. Press to select one of the following, and then press OK. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every fax you send. Fax On Fax Receive Prints a fax confirmation report for every fax you receive. Send & Receive Prints a fax confirmation report for every fax you send and receive.
SOURCE: Master Reset
I don't have a 6310 but I do have 4 printers one of which is a 5610. I never bothered w/ a reset switch because I would just turn the printer off, then unplug everying for 2min. Then I would reconnect everything back. If it doesn't work, I suggest you uninstall the software and reinstall it again. Let me know if this helps.
SOURCE: My new 6310 HP won't receive faxes.
Hi
when you installed did you get the fax setup wizard during the installation. If not, you can get it by opening hp solution center-> settings-> fax settings-> fax setup wizard.
You can have the HP solution center icon in the desktop or try with hp Director.
if not you can look at the
hard-copy user guide walks you through all the setup variations, depending on what type of line you have, what components (answering machine, for example), and how you want to handle incoming calls and faxes.
Good Luck
SOURCE: when I copy, send a fax, or scan it turns out HP 6310 all in one
this is a hardware issue..connect the printer to the wall outlet..and then try to make a copy..if its still the same then machine should be replaced..reason is scanner blub is gone bad..
SOURCE: Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
