SOURCE: Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
SOURCE: machine fills and agitates, but won't drain
It sounds like you pump is clogged. If there is something stuck in your pump the motor can't spin it to drain the water. If that is the problem then it's easy to fix. Simply clear the pump and put it back on, just make sure to clamp off the hoses to the pump with hose clamps or you will have water every where. If that is not the problem though then it means that your timer is bad and that is a little more expensive. Try the pump first though and hope that that is all it is. If not, like I said, you will need a new timer but most likely your pump is just clogged with something that is causing the pump motor to not spin. It could be a coin or a hair pin or even a sock or something. Good luck and let me know if you have any other questions.
SOURCE: My Kenmore Elite top loading washer keeps filling
its suppose to start with lid down,the draining may be a faulty water level switch so this needs replaced.
SOURCE: My Kenmore Elite washer model# 11024942300 will
Sounds like the coupling between the motor and the transmissionis broken or stripped.
