That worked but why does this happen I got the key symbol and beeping with 0 on the displayThat worked but why does this happen I got the key symbol and beeping with 0 on the display
You can't post conmments that contain an email address.
Sounds like have inadvertently activated the child lock. To deselect you need to press and hold the start button for approx 5 secs or until the key light goes out. Hope this helps, please let me know if this works or if you need further assistance.l
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
