Question about Sharp R-1480 Microwave Oven
Hi, I am Sou. Gita Sanjit Karande, I have perchase microven of double grill from Indapur, Tushar Electrical, in 30/04/2010. but our microoven not rotate it's hot plate. we have given complent towards delear at solapur, there service engineer collect our microonven's motor last 10 days ago, i.e. we have nearly one month having problem though your expert not solve it in garanty period. How can other castemer belive your service. plze give attantion towards our complant & solve as early as possible to belive your service. Is it safe to use a microwave oven if the turning plate is no longer working?
    Top Expert:
  • Sharp Master
  • 66,051 Answers
SORRY but we have no customer service . This is a free advice website ONLY
Posted on Apr 24, 2017
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: No Light No Heat Wacky Display
First of all, how old is the oven? It sounds like 3 separate problems, but I would doubt that any were caused by using the grill on the same circuit. Most often, that will just blow the breaker. Importantly, have you had any other electrical items fail in the last few months? Have you had an unusual number of light bulbs blow in the home, or have they blown much sooner than you'd expect? A "yes" to these questions could indicate a fault in your house wiring which must be quickly addressed by the power company or an electrician. Barring those complications, here are my thoughts: I would say the oven light just failed. It could have had its life shortened or ended due to door slamming. For the display to return to 95.00 instead of 00.00, I would suspect that the control dial is worn, damaged or contaminated by grease, dirt, etc., causing a slight shorting effect. 95.00 is the maximum cooking time - the extreme top setting of the dial. This kind of controller problem could also be caused by grease or moisture on the control circuit board. This is most likely to build up when boiling on the stove without first turning on the hood fan (a must) or if the hood fan has a clogged filter or restricted air flow in the duct work. It could also be due to spraying cleaners directly on the control panel / keypad instead of using a slightly damp cloth. Lastly, the lack of cooking operation is most often caused by (yes, door switches or door switch mount trouble) a loose connection at the magnetron, or a bad magnetron. First to address would be the cooking problem, and the first thing I would check is door switches and switch mounts. The lamp would just need to be replaced, but in most newer models, you have to remove the outer cover, which means taking it down from the wall. Safety dictates that this is a two-person job, and you might need to have your original installation instructions on hand to do it. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you need to order any parts (other than a light bulb, which should be available at the grocery store) I would recommend Tritronics at http://www.wehaveparts.com If you have a problem with the controller, that would have to be professionally repaired. We do that for customers nationwide for $39.95 in most cases.
Posted on Jun 17, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Sharp Carousel Model R-9H56
Did you happen to spray any cleaner directly onto the keypad? Hope not. Just wanted to exclude that poissibility to save time.
Assuming this model does not have a feature allowing you to turn off the turntable via the control panel, the motor msay be failing. Or you may have a bad door switch.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 22, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: where can i find instructions for sharpe double grill & oven micr
Info on ordering Sharp UK parts / spares is here.
Posted on Jan 04, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Is it safe to use a microwave oven if the turning
If the microwave is still heating, but the carousel is not turning, this problem is commonly attributed to a turntable motor that has worn out and needs to be replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you with locating and proprly identifying the part(s) you need.
If you have any questions, please post back with your and let me know. I hope this helps you.
NOTE: To answer your intial question, YES you can still use the microwave oven, but it is recommended that you stop the oven about midway through the cooking process and rotate your food to ensure it is heated evenly. Early model microwave ovens did not have a rotating carousel and it was often listed in the cooking directions to rotate your food this way.
Posted on Mar 25, 2010
Testimonial: "Thanks, very prompt and detailed response :)"
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: microwave turns on but doesn't heat. Turntable does not rotate
The magnetron (the part that heats the food) is probably done, they tend to go out if the fuse didn't blow and it usually isn't worth fixing as the cost of the magnetron is almost what it would cost to buy a new microwave.
Sorry for the bad news.
Benjamin
My microven want heat the food
double check the heat setting is up, if that doesnt work your heating motor has gone and youl be better off getting a new one
Aug 01, 2012 | Microwave Ovens
I have one kenstar microwave convection.But I did not know which method is used grill and baking.
I have a kenstar convection microoven. But i dont know how to make a cake in it.Please help me
Dec 27, 2010 | KitchenAid KHMC107BT Convection/Microwave...
My samsung microven MD800SC / zam 1100 watts (made in Malaysia) is working but not heating anything. Kindly advise what is the problem.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 26, 2010 | Samsung MD800SC Microwave Oven
Micro oven not heat blowing
Basic Microwave Oven TroubleshootingTips
heatman101';';';l;
May 11, 2010 | LG LRM1230W Microwave Oven
heatman101
Mar 19, 2010 | LG LRM1230W Microwave Oven
Microoven model 860A is not getting heated
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
I've a microoven( samsung).Don't know how to bake,as i don't have convection mode.Only cooking,grilling and also i've combi mode. I want to know how to operate the oven.Want bake cakes. Plz help me out....
In India, you can download your owner's manual here.
If you don't find your exact model, I would download a few that are close to your number, and they may be enough help.
Otherwise, I would contact customer service via the links on that page.
Jan 08, 2009 | Samsung MW1030WA Microwave Oven
Setting the time on Sharp microovens.
Normally it's
Clock > time numbers > Clock
or
Clock > time numbers > Start
Sometimes it's
Clock > (1 or 2) > time numbers > Clock
or
Clock > (1 or 2) > time numbers > Start
If this doesn't work, please reply back with your model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 08, 2008 | Microwave Ovens
NATIONAL NNN -C 2000P LOW VOLTAGE PRIMARY GETS FREQUENTLY OPENED
There is something on the secondary side which is drawing too much current. I would check all electrolytic capacitors, zener diodes, transistors, and voltage regulators.
Mar 27, 2007 | Panasonic NN-C994S Convection/Microwave...
Sharp R-1480 Microwave Oven Logo
78 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
