Me using windows xp-sp2.
wen i opened the winchat from the system32, and given the ip add of a PC in LAN i am unable to initiate the chat,
started the network dde services,etc but in vain
pls guide me in this subject
Be advised that Microsoft has discontinued winchat after releasing SP2 for windows xp. and did not bother to make the necessary changes to make it functional to meet users needs. you should try something different third party products most of the are free!
try this one:
http://www.fomine.com/index.html
Both computors must be connected to the same network{LAN} or Internet as you probably know.Also ,each computor must be running a similar Protocol,such as TCP/IP.Please also recheck the ip address and whether you have not been barred by your destination computor.Regards
* check n|w cables are connected properly
* restart your system
* if server is down then check adapter is suppling power to router properly if not replace adapter
I hope this helps.
If this Answer goes some way towards helping to resolve
your Query, Problem or Fault, please take the time to Rate it. Doing so helps
Solution Providers, like me, better understand the needs and the point of view
of Askers, like you, and guides us in exploring the best ways to provide the
most comprehensive, useful and high quality Responses and Solutions we can. If
you need further help, please do not hesitate to post another Question or add a
Comment to this Question.
Thanks for using FixYa.
