Timex Expedition E Tide Temp Compass wristwatch Logo
Posted on Oct 26, 2010
Replace stem on Timex Expedition E-Tide Temp Compass Watch
Azmi Amin
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 06, 2023
Azmi Amin
Contributor
Level 1:
Answers
Questions
0
Helped
433
Points
I am looking for stem and crown for Timex Expedition North Tide Temp Compass watch. Mine broken.
replace stem on Timex Expedition - img_5569-n4crlj5iugjwuxfd5a023hit-d-0.jpeg
4 Related Answers
Anonymous
  • 2071 Answers
  • Posted on Jun 14, 2008
SOURCE: Timex EXPEDITION® E-TIDE-TEMP-COMPASS T45581
most of my repair does'nt have a manual,all i do is to sure that all,the function button is working.then proceed to try all the function to work and observed what is the result.that watch three sitting of the crown by pulling,first pulled little then wind left and right and observed,second half pulled,then wind again third full pulled for hands function.Try this and you find the result.
Anonymous
  • 183 Answers
  • Posted on Sep 21, 2009
SOURCE: Timex Expedition E-Instruments E-Compass Watch
Timex makes its manuals available for download from their website:)
http://www.timex.com/gp/node/n/255235011/178-9815641-8595102?ie=UTF8&timexBrand=core
Anonymous
  • 2501 Answers
  • Posted on Jan 28, 2010
SOURCE: Timex Expedition Compass watch stops randomly.
Some watches have crowns that screw in after being pushed home, is this the case with yours? If it is then that could cause the problem described. (Turn crown clockwise).
I looked at one or two of the Expedition instructions (the are a lot) but couldn't find any mention of a screw in crown.
I suggest that you go to Timex.com and at the bottom of the page is "manuals/downloads" select this and the "product manuals". Put your watch type in the search box to obtain your manual.
If you are still not able to solve the problem, the I suggest you take it back to a Timex dealer to sort it out.
Anonymous
  • 714 Answers
  • Posted on Feb 10, 2010
SOURCE: instructions for timex e-tide temp compass watch
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
My time e-tide compass sohws large deviations (>90 degrees) after calibration. I've tried calibration several times, each resulting in slightly different north. The degree of variation per heading...
Low battery can cause this type of fault! Make sure after changing the battery to do the all reset inside of the watch. If this does not work get in contact with Timex for how to have their watch sent for service.
How to calibrate timex compass
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
Manual for timex expedition e
If you are still unable to locate your user manual, you may email Timex Customer Service or call toll-free at 1-800-448-4639
4helpful
How do i calibrate my compass on my e tide watch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please..
Jan 28, 2010 • Watches
1helpful
I have a Timex e-tide with compass, temp and tide functions. The compass no longer points north and will randomly point in any direct when activated, is there a way to re-calibrate the compass?
Hope this tip helps
R/
David
4helpful
Instructions for timex e-tide temp compass watch
Hope this tip helps
R/
David
Timex exp e tide compas will not work / calibrate
i would advise you to contact timex customer services .
5helpful
2answers
No instruction manual
For Compass Adjustment search on Google or FixYa
For Temperature calibration:
1. Pull the crown to most extended position (2 notches)
2. Temp hand moves to a default position
3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
4. When done, push crown to 0 position
(I used melting ice water to calibrate and fix to 0 deg C)
For Tide calibration:
1. Pull crown to middle position (1 notch)
2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
3. When done, push crown to 0 position
Hope this helps
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
