SOURCE: Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
SOURCE: TEC B 572 WHEN USING
This may be a firmware problem! or problem on the communication port
This is a syntax error detected by the machine
SOURCE: My tec 572 printer is displaying an error msg.
Syntax error;
Wrong size of labels or wrong graphic types
