GE JVM1190SY/WY/AY/BY Microwave Oven Logo
Posted on Oct 26, 2010
GE JVM1190SY 002 MICROWAVE SECTION WONT HEAT - GE JVM1190SY/WY/AY/BY Microwave Oven
5 Related Answers
Anonymous
  • 525 Answers
  • Posted on Jun 03, 2008
SOURCE: Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 04, 2009
SOURCE: GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Anonymous
  • 563 Answers
  • Posted on Feb 04, 2009
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Gregg Rene
  • 86 Answers
  • Posted on Mar 22, 2009
SOURCE: GE JVM 1330 WW 002 Microwave
900 Watts. Here's a link to the manual:
http://genet.geappliances.com/DocSearch/pdf/49-40092.PDF
Anonymous
  • Posted on Apr 09, 2009
SOURCE: need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Ceramic tray
If not available for purchase from the maker try to Google the item on the internet.
Hi...have a ge micro jvm1190sy 011 i melted marshmellow in it....it bubbled over and is now stuck in the ceiling of the micro on top of the whole metal sheet i can not clean it so there is layer...
How about boiling a small container of water and once it starts boiling. Just shut the unit off and let it sit and let the steam do the work for you. Might soften it enough to scrape it off.
After starting it begins to smell like burning rubber.
there must be some internal part that could have melted. would get it checked out
4helpful
GE JVM1190SY/WY My microwave shows no signs of receiving any power. The light won't even come on. I have tried plugging it in to several different outlets, all of which tested good for a 120 volts. ...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
My GE Profile microwave is not heating anything up. Everything else seems to be working normally.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
1helpful
Does GE JVM1190SY Profile have internal fuse? If so, how do you access it?
yes it does, open the door and on the inside edge of the control panel is a couple screws. take them out and you can open the panel the fuse is located behind the panel in the micro up near the top.
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
2answers
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
