Cell Phones Logo
Posted on Oct 26, 2010
I accidentally Block messager by address. Meaning, I can't receive sms from the person I accidentally blocked. How to unblock?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2051
Points
20
You can unblock in the message settings. For my phone, (S8500 Wave);
settings->applications->messages->general settings->block message
and select delete, then select the number you want to unblock and select delete again.
Might be slightly different process for different phones though.
How to block text messages
You can block text messages from a specific number or contact on your Android device with a third-party solution. Just follow these steps.
Blocking Text Messages
Option 1
Note: These steps are for the stock “Messaging” app included with Android 5. Some carriers may include a different app for messaging.
Open “Messaging“.
Press the “Menu” Menu icon icon located at the upper-right corner.
Select “Blacklist“.
Set “Blacklist” to “On“, then select the plus (+) to add a person to block.
Type the number you wsih to block. Check “Block incoming calls” and/or “Block incoming messages” as desired, then select “OK“.
If you wish to remove a number from Blacklist, select the number, then choose “Delete“.
Option 2
If your messaging app does not offer a Blacklist option, use Handcent.
Download and install Handcent SMS for your text messaging needs. It’s available in the Google Play store.
Since you’ll be using Handcent for text messaging, disable the notifications for your current text messaging app. Otherwise, you’ll get double notifications for text messages.
Open Handcent then select the “Menu” Android menu button icon at the upper left corner of the screen, then select the gear in the lower left corner of the screen.
Select “Security & privacy” > “Manage blacklist“.
Tap the plus (+) icon to add the phone number you wish to block. You can choose one from your contacts, call logs, or input the number directly.
Now all of the text messages from that person will be blocked and not visible in the Handcent app. You won’t get notifications you’ve received a message from the person either. If you ever want to unblock the person, return to the “Manage blacklist” screen, tap it, then select “Unblacklist“.
Some users have reported that the app “Private Space” works well for them.
Sending an Automatic Reply
If you want to let a person know they have been blocked, you will need to download and install SwiftReply. SwiftReply will allow you to setup an auto reply for specific Contacts.
Ensure the mobile number you wish to block is listed in your Contacts.
Open “SwiftReply” and tap the plus icon (+) to make a new auto-reply.
Type the name you would like to use for the reply and the text you would like to send to the person.
Scroll down and select “Enable User Filter” > “Contacts“.
Tap “Add” and choose the people in your Contacts list that you would like to receive the reply. Tap “Done” when your list is complete.
Tap “Save“, then tap “Off” to turn the auto-reply on.
The specified people will now receive your message automatically and Handcent will block them from your view.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/josem_e9ac89730196f220
Feb 04, 2016 • Cell Phones
1helpful
3answers
How to unblock a contact
Check weather u have put that no. in black list or not?
for this go to call setting and locate any option like :Call block or Auto Reject or Reject list etc" if found then open it and remove that no. from there...
Watshapp chats
How do I block or unblock a contact? You can prevent a contact from sending you messages by adding their phone number to your Blocked list. To learn more about the effects of blocking a contact, see this article on blocking contacts in WhatsApp.
On iPhone, there are two ways to block a contact:
  1. Use the Block button which is displayed when you get a message from somebody who is not in your address book:20950271-en-01.png
  2. Go to WhatsApp > Settings > Account > Privacy > Blocked, then tap the Add Newbutton to add contacts from your address book to your block list.
To unblock a contact, open the Blocked list with the above steps, slide your finger to the left on the contact you wish to unblock, then tap the Unblock button.
Learn how to block or unblock a contact on: Android ' BlackBerry ' Nokia S40 ' Nokia S60 'Windows Phone ' BlackBerry 10.
1helpful
I have blocked an adress by Messages; now I cannot receive any sms from that contact. How can I unlock this contact for to get the messages again? Thank you
Usually the same way you block them is the way you also unblock them but sometimes you have to use a computer depending on the make and model of the phone.
2helpful
I accidentally block some of my contacts on my samsung corby2 can u help me to unblock
Have you been try the Coolmuster Data Recovery software? This software can help you recover your Samsung phone contacts at ease, you can have a try.
Read more: http://www.coolmuster.com/android/recover-photos-videos-from-galaxy-nexus.html
16helpful
2answers
I have accidentally blocked a number on my samsung gt e2121b and now cannot receive texts from it. how do i unblock it?
Hi To unblock the accidentally blocked number you need to do the following Press the MENU key Select MESSAGING Scroll down the list and select SETTINGS Select TEXT MESSAGE Select BLOCK NUMBER Highlight the number you wish to unblock and select OPTIONS Select DELETE Select either DELETED SELECTED or DELETE ALL and press OK Briefly press on the ON/OFF button to return to the Main Screen
Unblock
Did you mean how to block someone on facebook.Follow this steps.
  1. Go to theBlock lists from your Privacy Settings page. Enter the name or email address of the person you want to block in the appropriate field and click "Block."
  2. If you cannot find someone using the Person search field, try going to their profile page. You can block them by navigating to the "Report/Block this Person" link at the bottom of their profile page. Once you click this link, check the "Block this person" box and then click "Submit."
  3. Lastly, please note that you can block someone through the "Report" link located next to messages in your Inbox.
2answers
Unblocking number
just a guess....
search for " screening or block number " at phone/numbers or message/text it may help..
then the rest is up to you..
9helpful
2answers
Blocking text message sender
Go to Messages --> settings --> General Settings --> Block Messages
then remove the number from By Address .
Now you will receive the SMS from that friend
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
