SOURCE: 2701HGB modem - dsl light flashes red
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire 2701HG-B.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
SOURCE: DSL modem connected but no internet
Have you installed DSL filters on all your phones and make sure you don't have on on the line for your modem?
SOURCE: Speedstream 4200 setup
To configure my siemens 4200 modem I enter 192.168.254.254 into the address bar of the internet browser. You should get a login screen that ask for your user name and password. Default user name should be admin and the password should be admin. I hope this helps you
SOURCE: Intermittent DSL connection
hi, i happen to be one of the technical support agent of this dsl modem/router..it's very simple...there are a lot of factors that may cause the intermittent connection...one could be the filter if it's hard wired, or EMI's... or defective ethernet cable...however, if it's wirelessly connected to the computer...there could be problem like slow browse, no browse or no connection at all if there's a wrong configuration of the modem...
SOURCE: Modem only shows two lights; can't connect my PC to the internet!
It sounds like you've lost connect to your ISP. Have you checked with them to make sure you don't have an interruption of service?
If it's not an IOS, work with the ISP support technician to trouble shoot. They may have to replace the modem if they can't isolate the problem.
