Sounds like electronics not working.Try The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
SOURCE: no internet light on modem afer router is used
go to http://support.dlink.com/chooseCountry.asp
for proper set up of the router...most likely it has conflicting IP Address's. If they wont help you can contact your ISP for support or get a differ router.
SOURCE: DLINK ROUTER DI-624M
Press the reset button on the back of the router and hold for 10-15 seconds, this resets router to factory defaults. Access the router using the IP address of the router http://192.168.1.1 access the router setup and create your PPPOE internet connection provided by your ISP using your username and password connect to the router via the computer. BPCS
SOURCE: DI-524 status led not blinking
Here are the instructions
Hope this helps.
Also you can visit the link :: support.dlink.com/products/view.···DI%2D524 for further assistance
Please rate this solution!!!!!!
SOURCE: reset DLink router to factory default
All you need is your ISP log-in name and password.
Connect the router to your computer with an ethernet cable, log into its web server (generally 192.168.0.1) Get past the gatekeeper (admin and admin) and then navigate to the set-up page and re-enter your ISP info. That normally is all there is to it.
