Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Hi
Check
the back wall or floor of the freezer section for frost. Check the freezer (
evaporator) fan to see if it is running. Check the condenser coils under the
unit for blockage from dust. Check the condenser fan (under the unit) to see if
it is running.
If you have frost in the freezer there is a problem with the defrost system and
the freezer will start to warm eventually as well as the fresh food section. If
that is the problem you can check the defrost terminator, defrost heater/s, and
the defrost timer or adaptive defrost control If used on your unit or the main
control board if so equipped. These things usually require dismantling the
freezer and other areas of the refrigerator to be checked.
There
can be many factors for the no cooling factor: the condenser coils could be
blocked with dust, the condenser fan could be bad or stuck, the freezer fan
could be stuck or bed, the freezer coils could be blocked with frost because
the self-defrost system is not working or the compressor is not running because
of a bad relay etc.
Please
check this link to get a detailed idea about your issue:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please
get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
The newest defrost
feature in modern fridges is the electronic adaptive defrost control board. Maytag/Jenn Air has one version, see diagram...to
put this adaptive defrost style of fridge into defrost, short with a small
screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds
and you should hear a "click" noise from the relay and the fridge will
shut off and go through a defrost cycle.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
