SOURCE: coleman compressor no build up of pressure
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
SOURCE: I have a 1hp 7gal that makes just 40lbs keeps running
if this is piston driven you need new rings if rotary then you need new air inlet valve unless you have oil in air line then it would need bearings and seals
SOURCE: install reed valves hitachi air compressor need pics
I believe in your model of air compressor, when you take apart the head portion to your compressor you should have four reed valves. When you have it apart, there should be two "grooves" on the bottom "plate" and two "grooves" on the top plate (where the reed valves go). the bottom part is easy (as you should already know) to set in the reed valves, but as i have also found out, as you probably have, that its a little more difficult to line up the other reed valves to thier "grooves" on the upper "plate". What you do to make sure that they stay in place is dab a little oil or grease on the reeds and place them in the upper "plate grooves" and carefully set the upper plate back in place where it goes on the compressor. It will hold them in place long enough to install it on the compressor and the small amount of grease that was there will quickly be burned up with no effect to the opperation to the machine.
Sorry, long winded explanation. hope this helps and if it didnt get to you soon enough i hope it helps out in the future. :-D
SOURCE: i have a dewalt air compressor model d55155 will
If you have oil coming out of the oil fill and dip stick you most likely installed the reed plate upside down. Usually it says this side up or there is an arrow pointing up on the reed plate.
This is a good sketch of compressor and reed valve assy.
http://www.about-air-compressors.com/images/1055.gif
Usually the reeds are on top of the plate facing downward. If you have just a reed disc.. then the disc will need to be inverted.
Thanks for Choosing FixYa.
Kelly
