Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have liftmaster professional garage door opener. it opens ok but does not close with remote and light keeps flashing on garage door opener. I checked both sensors and seems like the sending sensor light ( orange) does not glow. receiving sensor (green) light flashes sometimes. when I press wall button for garage door the orange light turns on and garage door closes. I am not sure if it is faulty sensor or what? wiring to sending sensor looks ok.
    President:
  • 3,197 Answers
If your sensors are not pointed at one another the light on one of them will go out. Tweak them a bit. If you cannot get the light to come on then your sensors are bad.
Posted on Oct 25, 2010
6ya staff
SOURCE:
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
I have Garage Door Opener from Sears. Wall push button & the the remote from my car open the door OK , but it does not close the door from my car (which is programmed) Wall push button close the door...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster 2265 1/2 hp remote does not close
If the door starts to close and the main light flashes 10 times and the door reverses to the open position it is a problem with the door sensors. Make sure they are pointed at one another and they each have a small light that must be on and not flickering.
If it starts to close but reverses and the main light does not flash 10 times it is possibly the RPM sensor which is a small printed circuit board just in front of the motor.
Nov 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote opens door but will not close door (Liftmaster)
If when you try to close the door with the remote the main light flashes 10 times and the door reverses to the open position you have a door sensor problem. Usually it is because one of them has been bumped and is no longer pointed at the other one. If they are pointed properly they will each have a small light that is lit and not flickering. Tweak them a bit. If this doesn't work and the lights are not on you most likely have bad sensors.
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light flashing after opening
look in your book it will tell you the problem count the numer of blinks
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Flight flashing on liftmaster 2000
Apparently this problem is caused by weak batteries in the remote, I changed them and that solved the problem
Steve
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
734 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
