If u r still having this problem with the imagerunner 3570 u can try this:
press * 2&8 together then * again
go to function
then to clear
select eroor then ok that should take care of ur issue
www.fixya.com > ... > Canon > Canon imageRUNNER 2870 Copier ... error code e000024-0001 E000024-001 is a problem with the developing assembly it's usually either a faulty toner sensor sometimes just toner stuck to it just ...
check for paper jammed in fuser assy, u need to reset error code by pressing smarthead then 2and 8 SAME TIME then smarthead should go into service mode press copier then function then err ok then off on
fixing assembly overheating, the temperature of the fixing assembly is abnormally high.
turn the machine off for some time and then on it. if it continues indicating, reset condition in service mode ( copier>function>clear>err). replace main thermistor. replace DC controller PCB.
it might just be a power spike in which case your machine just shot an error while it protected itself...
try the following... press additional functions press 2 and 8 at the same time press additional function press code error press copier press function press clear press error press ok press reset
if that doesn't work then call a tech... it might be very serious...
Ok here is how to reset the error if that doesn't work... you really need to call a tech... you are going to need some serious work done on your copier... ok... here are the instructions
