Read more: 1+3+5+7+9+11+13+15+17+19=100 , to make 50 use only 5 digits ...? what the 5 digits.Read more: 1+3+5+7+9+11+13+15+17+19=100 , to make 50 use only 5 digits ...? what the 5 digits.
You can't post conmments that contain an email address.
I use straight coolant on my 01 Ford Taurus. I'[m sure you can get a way with a 50/50 mix in the summer months. You do not want to use 50/50 in the winter.
Hi! I have noticed a lot of people have this problem that they actually forget there Sony Ericsson mobiles' Phone Lock Code. If you want to recover your phone lock code please go through the following procedure. This procedure will tell you your mobile's lock code without flashing and resetting of any kind!..
I have also have a Nokia version of this tutorial here: Nokia Follow these steps;
Open this link, select your phone and download the software. (PLEASE CLICK HERE)
Follow the onscreen instructions to install the software.
Once installed, turn off the mobile and remove thebattery. Now reinsert the battery and insert the cable (DCU-60 thatcomes with the box) while holding the 'c' or '@' button on your mobile.
Your computer will detect a new device and install it.
Once installed please unplug your mobile, remove the battery. Now reinsert it.
MAXIMUM LOAD WARNING
45 and 50 CALIBER RIFLE:
45 Caliber Pellets come in one size: 50 grain
50 Caliber Pellets come in two (2) sizes:
50 grain volume equivalent which equals 50 grains of loose powder by volume.
30 grain volume equivalent which equals 30 grains of loose powder by volume.
The maximum load per shot should never exceed total Pellets containing more than 100 grains volume equivalent. That means, no more than:
45 Caliber 1) Two (2) 50 grain Pellets
2) Three (3) 44/45 caliber 30 grain
50 Caliber 1) Three (3) 30 grain Pellets, or
2) Two (2) 50 grain Pellets, or
3) One (1) 50 grain Pellet and one (1) 30 grain Pellet
54 CALIBER RIFLE:
54 Caliber Pyrodex Pellets come in one size only:
60 grain volume equivalent which equals 60 grains of loose powder by volume.
The maximum load per shot should never exceed 120 grains (2) Pellets.
Take 51 sheets of "graph-paper" (1+200 minus 60 minus 50 minus 40).
On the first sheet of paper, label the graph-title as 'Z=40'.
Label the X-axis from 60 to 200.
Label the Y-axis from 50 to 200.
Draw a straight line from (X=60 and Y=(200-60-40))
to (Y=50 and X=(200-50-40)).
On the second sheet of paper, label the graph-title as 'Z=41'.
Draw a straight line from (X=60 and Y=(200-60-41))
to (Y=50 and X=(200-50-41)).
On the next sheet of paper, label the graph-title as 'Z=42'.
Draw a straight line from (X=60 and Y=(200-60-42))
to (Y=50 and X=(200-50-42)).
On the second sheet of paper, label the graph-title as 'Z=43'.
Draw a straight line from (X=60 and Y=(200-60-43))
to (Y=50 and X=(200-50-43).
Keep going for all 51 sheets of graph-paper.
Stack the 51 sheets on top of each other,
to visualize the "3-D" solution to the problem.
P.S. Don't tell your school-teacher that I helped you do your "homework".
