The wires to the igniters need to be replaced, our did the same and drove the technician nuts for 6 months...he wrapped them in electrical tape after seeing one arc...new wires fixed the problem.
Spark module part no 318 at parts diagram it may be wet and by using a hair dryer or leave it unplug for some days can dry out and stop. If not then the electric contacts are stuck and need a new spark module
The clicking is the igniter. If it is clicking and not lighting, then you may have to purchase an igniter kit and replace it. the relays can go bad, or igniter fails.
It is possible that once the unit dries out the clicking will stop. If it doesn't, you will need to call someone to have the problem addressed. You will need a spark module and or an ignition switch(s).
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
