SOURCE: one red flashing light on 360 and error code E73
which light is it? (xbox hd facing up)
anyway.
http://forums.xbox-scene.com/index.php?showtopic=484726
SOURCE: my xbox has got 1 red ring of death E73?
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet
port
It is actually the solder under the GPU which is giving the error code.
Is it covered under warranty from Microsoft? If not we can fix this for you.We are listed on this site for repair service.
www.videogamerepairservice.com
SOURCE: sysem error E73 on Xbox 360
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
SOURCE: I am getting an error message E73 on my XBox 360
there are a lot of diffrent walktroughs on you tube for this problem decide whitch is best for you. or go to www.xbox.com/support/contact
