E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
Posted on Jun 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Emachine laptop - M6805
No power to the computer. It stays black. I was "defragging" it and when I came back, it was black.
  • Dot_ Jun 08, 2008
    Since I cannot get any power to the computer, I cannot get to any mode. Thanks for trying.
Anonymous
Level 3:
  • Master 790 Answers
  • Posted on Jun 08, 2008
Anonymous
Master
Level 3:
Answers
790
Questions
Helped
298899
Points
2256
Go in safe mode and restore ur system to previous date ...
Itt urns on but it stays on the emachine bootup
We can only try for a power drain for this issue,
all you have to do is unplug the power cable from the computer and battery too, then press and hold the power button for 40sec( without battery and power chord), then connect the power cable back. then try to turn on your computer,
Hope this will work!!!
Still if you are facing the issue then you need to consutl with a local tech because it might be the issue with the hardware
Computer frozen and start up button doesnt work
you should manage your start-up programme. 1. use "msconfig" command to manage the start-up applications. 2. use this free registry defrag to defragment your registry and speed up your computer.
3helpful
2answers
How do i install memory in my emachine m2105
the maximum memory allotted that machine is 1.2 gigs and to do so you open the bottom memory door ans slide out the slot card and reinsert the new one
2helpful
3helpful
2answers
My emachine M6805 will not boot up. It gets to
Do you have a recovery disk set, or is there a recovery partition on the hard drive?
2answers
Screen goes blank after booted up
try replacing the memory module on the laptop as the resources on the memory is shared with the graphix
Screen problem on m6805 emachine laptop
This sometimes happens if there is a cold solder joint, very delicate job, if you are going to open and fix yourself "Take your time"
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
