Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Jun 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi HD 1080 wont turn on now
This TV is just at 5 years old and has worked great with no problems until out of the blue it has no power and will not turn on. Thanks for any help.
Ken tv will not turn on power light continues to flash. Tried hard reset, no luck.
Tried the reset on the front of the tv, no luck. Checked the fuse in the back, it is good. Now what? I would like to watch it, but it will not turn on.
Thank you I hope you can help.
Sincerly
Susie Valle
  • lesset Jun 08, 2008
    Thanks for your help, but I got it to turn on.
    I pushed the reset a bunch of times, the light continued to flash then went off. It worked to my surprise. At least it is working for now. I hope it lasts. This has been happpening for a couple of months. This being the longest time off.
    Thanks agian
    Susie
    I checked the fuse, it was good. I used to be a digitronics tech so touching was not an issue. Thanks for you info. It is working after pushing the reset numerous times.
chris beachel
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Jul 25, 2019
chris beachel
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
1067
Points
I have a mitsubishi wd65737 and when I go to turn it on the green light blinks three time and shuts off
Anonymous
Level 3:
  • Master 983 Answers
  • Posted on Jun 07, 2008
Anonymous
Master
Level 3:
Answers
983
Questions
8
Helped
434468
Points
2838
Have a check with the transformer ...
there may be any miscontact in transformer ...
  • Anonymous Jun 07, 2008
    some capacitor might have gone or it is getting heated too much ... so may be due to excess temperature of the transformer or the capacitor it is not working ..
    have a check with this .............
Ekse
Level 3:
  • Mitsubishi Master 13,435 Answers
Ekse
Mitsubishi Master
Level 3:
Answers
13435
Questions
82
Helped
3984686
Points
38023
This document may be usefull
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
heres a picture of bad capasitors
http://www.auctioncreations.com/wd62525a.JPG
This text was written by another expert on this site, CTF1800:
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
  • Ekse Jun 08, 2008
    I'm not sure is the problem solved completely but if you are satifyed you may press the accept button on the solution of your choice.
Anonymous
Level 2:
Scholar:
  • Expert 198 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
198
Questions
Helped
76539
Points
328
Did u by any chance open the assembly of the tv and touched the pcb board... the circuits on this board r very delicate and u shud be very if u r handling tis....
wen u switch on ur tv r u able to listen to any sound or wat?
if yes reply back, i wil help u
I have a mitsubishi hd 1080 65315 model and the code is 23 what is the problem.
Mitsubishi TV Shutdown Troubleshooting - Stereo & Video ...
www.stereoandvideorepairco.com/.../MitsubishiShutdownTroubleshootin...
For example, the sequence: blink-blink, pause, blink-blink-blink, indicates an error codeof 23. This sequence repeats 5 times, so you can figure out if you are ...
Mitsubishi VS 50705 error code 23 - Service manual, repair and ...
forum.eserviceinfo.com/viewtopic.php?t=81051
Oct 24, 2010 - 10 posts - ‎4 authors Tv is old about 10 years. Shows error code 2-3 horizontal deflection failure. A few years back had a leaking crt, replaced the caps recomended ...
My mitsubishi 42' hd 1080 tv turns off immediately after i turn it on.The set is about 7 years old.HELP!!!!!! niteowl42
Have you acessed the power indicator error code by pressing in the menu and input buttons on the front of the set both in together and hold in for 5 seconds? The led will blink a series of blinks to indicate a 2 digit code which will repeat several times. Let me know what the blink seqience is.
2answers
My PS3 connects to my 3yr old Mitsubishi HD tv fine via HDMI or the analog connection. However, using the same cable(s) it won't do anything but flash a squiggly green line a couple of times on a 6 year...
yup one or the other is capped at or below 1080 P - I so when you go to power it up at a new tv push and hold power till it makes the second beep 5 secs later and your good to go ok :)
13helpful
2answers
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
7helpful
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
You most likely have a blown fuse and its not very hard to change it.I'll try my best to walk you through it.Pictures have been added to make it  simple.First  remove all the panel screws 1.3f3f5df.jpg
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
