There are several possibilities...but the most common is that it asks to press F1 to get into bios and set the basic system like date and hour...My advice if it asks this when you boot..is to press f1..than in the BIOS settings choose the optimal factory defaults .( cause that might be other parameters not set proper) and after that ..press F10 to save changes..and enter to confirm and exit ...after that set the date and time from windows cause it is much easier..
If this is not happening all the time ..follow it and see if it happens after you drain the battery and it is turning off when it is on accumulator ..this means that the BIOS battery is dead and every time it gets without any external power source it will basically act like when you flash the BIOS by jumping or removing the battery ...CHANGE bios battery cause is dead..
SOURCE: 162-System options not set
i had same problem ,when i pulled off the cmos battery for 5 min and then put it back and switched on the laptop ,it was ok and there was no problem and it worked ok.
Asif malik
SOURCE: 101-I/O ROM error and 162-system option not set
sound slike theres a fault with a cd dvd drive or that it's disconnected, possibly the driver is corrupt
SOURCE: 162-system option not set
The cmos (bios) batter has gone.It's the size of a tablet and costs about two pounds (5 dollars, 3 euros, etc) but it's hard to replace unless you know what you're doing. The batter is normally underneath the laptop under a hatch, and perhaps under the ram memory, or hard rrive, or wireless network card.
If you are talking about the password that is just ask when the comp starts....You can try this...
The power-on
password prevents use of the computer until the password is entered. The
setup password prevents unauthorized changes to
Computer Setup. To clear the
passwords, you must remove all power from the
system board. If you do not know the
passwords, use the following procedure to clear
the password:
1. Remove all battery packs.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait thirty minutes.
5. Reconnect the AC power. DO NOT INSTALL THE
BATTERY!
6. Restart the computer. During Power-On Self Test
(POST), a â 162 System Options
not setâ message appears.
7. Shut down the computer, then disconnect AC
power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10. Reconnect the AC power.
11. Start the computer.
1. Error: BOOTMGR is missing:
• The following error opens when attempting to start the PC:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
