Belkin (F5D7230-4) Router (587009) Logo
Posted on Jun 07, 2008
My belkin light is on but the internet connection to my laptop keeps breaking up consistently
I have a main pc downstairs with a wireless rooter attatched to it, and then I have my laptop upstairs with a belkin wireless USB network adapter connected to it. The internet connection keeps on breaking up, and I keep having to go downstairs to make sure all the green lights on the wireless rooter are on, and then sometimes the internet comes back on, but this is only for about five minutes or so, until the connection breaks again. The light on the wireless adapter is on all the time, but my internet hardly ever works on my laptop, and on the downstairs pc it works a little bit better but is still not reliable.
  • 2 more comments
  • chechiwest Jun 10, 2008
    the same thing... the belkin is connected to my house's pc, then i connect in my laptop and the connection works for about 5 min.. then it doesn't work again, i have to restart my laptop and again, the conection only works for 5 min.. it doesn't disconnect, just stops working
  • zieko Jun 10, 2008
    hi my belkin f5d7230-4 has all the lights on, the internet is directly into this via cables to 2 pcs, yet my internet will not work at all.
    this is a fairly new router. when the broadband is only via the modem the internet works fine.
    please help
  • dmhandyman Jun 06, 2017
    Take the laptop down and put it right next to the router. Try it for a while, if that solved the problem, the laptop is not getting a good enough signal from the router. If that is it, you need a better router and adapter on the laptop.
    That that doesn't help, it might be a bad Internet provider. Where I am, it is often both of those problems at once.
    Since it is so unreliable on the desktop p.c., it does sound like both problems. Still, try putting the laptop next to the router.
    May need to replace the modem, but I'd call the ISP (Internet Service Provider) first to see what diagnostics they can do. Be aware that some ISP's will NEVER admit it is their fault.
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Jun 07, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
4903
Points
25
This sounds like it is probably the networking cables as your PC is directly connected so shouldnt have problems with net access. Get new cables as a first step :0)
Here what is happen my sister law had a Belkin router that went bad she got a norther Belkin router not the same one but it a Belkin here what going on she try to hook it up and she Chang to use broadband...
The ISP modem connects to the wireless routers main port. Then connect the PC to any other port on the router.
Use the default wireless settings that Belkin provides. There is a small tag under the unit with the default information. Or, use custom settings in the web admin.
3helpful
How To Use a Belkin Wireless G Router as a range extender? I'm trying to hook my Xbox to the internet, the problem is that the xbox isn't wireless and internet comes from a wireless modem and is...
You can Convert the Router as an Access Point But your Wireless Modem Should Be Hard wired to router. But if your Router has an wireless Bridge Option in it you can Convert it as an Range Extender. Check For the Wireless Bridging Feature on your Router or Please Post your Router's Model Number Here. I Will Be Glad to Help you out... :)
I have just purchased a belkin cable rooter n+wirless rooter, I have two questions 1 - Set up secruity word router attached to wired pc. wirless lap top can connect but does not ask for password. why is...
1. Belkin makes you not only setup the wireless/WEP but you have to turn it on as well. (radio button I think) Some also have a separate configuration for N vs. B/G, since it does both. check your setup
Look under "Wi-Fi Protected Setup" in the configuration.
2. This is normal, that's your power light.
Cant connect to internet with main computer, one upstairs is fine
The upstairs computer is wired or wireless ?
If the upstairs computer is working then the router must be working properly.
Check the connection between the downstairs computer and the router.
If it is a wireless computer then check the wireless connection status on that computer.
Click Here for step by step solution
2helpful
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
My internet keeps disconnecting
It sounds like the wire from your house to the isp switch is faulty you should probably call them down to fix. Or it could just be the modem are you using the same modem for both computers? If so then that's probably the problem.
I have a belkin router fd8633 the wireless light is not on and I cannot connect wireless to the internet. Just got a wireless laptop so want to connect wireless as well as wired on pc any ideas why it...
The main problem here is the wireless light being off, because it means there's a problem with the router, so the best thing that you can do here is to reset the router by pressing the button for 15 seconds and hopefully the wireless light be lit that time , if not I may suggest you to contact Belkin for this concern and if the router is stuill under warranty it will be replace...
Hope that helps.........
I keep losing my signal intermittently on my Belkin MIMO plus wireless router it constantly goes up and down from 1.0 Mbps to 54.0 Mbps interferring with my connection. The router is connected to my...
your gonna need the belkin router amplifier for that if its too far away from the router its gonna loose signal and cause you to intermittinly loose signal and connection ./... you could also contact belkin support at www.belkin.com/support
Wireless router blinks
just remove & replug your adapter
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
