We are having trouble setting up this television because we do not have a manual. The timer light blinks but the tv does not turn on. What should we do?
Sony has provided a "self-diagnosis function"
with your TV, that in the case of abnormalities or problems the LED or
red blinking light on the Timer/Standby indicator flashes a number of
times to indicate the issue. when there is trouble with your
Sony Television set -- it indicates the issue in either the diagnostic
mode, or even more commonly by flashing a series of LED blinks or
flashes on the front of your television. Each set or frequency of the
blinks indicates a very specific problem with the television itself. Sorry but unless you may be able to repair the television set yourself , please call a local repair shop
to the have a repairman sent out,, Take care and please Remember to rate/vote for us to continue for Helping out the Community :)
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes Sony has provided a "self-diagnosis function"
Look closely at the flashing light... Does it flash in a sequential pattern like 4 blinks, a short pause then 3 blinks, a short pause and then 1 blink or some similar pattern????
If so, then the light is not a timer light, it is a trouble indicator light and signals that a component inside the TV has failed testing when the unit tried to power on.
If not, then I have no clue about what you're describing as a timer light. I am unaware of the Misubishi having a timing light installed.
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Try pushing the Imput and Menu buttons in together on the set and hold for 5 minutes and see if it blinks out a two digit code. Then let me know. Also these sets have a tendency to have some faulty capacitors on the DM board. Hope this helps youout.
Refer to the trouble-shooting section of your manual. Usually, with this technology, the lights (Lamp/Temp) on these sets are also used at diagnosis/fault indicators... so, your manual should tell you what a flashing TIMER light represents. If the manual, doesn't provide this information, then ring JVC and ask one of their technicians.
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
