SOURCE: unable to make coffee automatically using whole beans
The rivets in the back of the Jura Capresso units are actually oval security screws. The bit that removes these screws are made of a very hard metal and cost me over $50.00 two years ago. Also many people who attempt there own repairs tear off the little plastic tabs that keep everything together nice and tight. We repair Jura Capresso Krups Bosh etc. www.hotncold.com
SOURCE: machine shuts off after beans are ground & sometimes when pot is 1/4 full
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. Serial number is engraved onto the very bottom of the coffee maker - hard to read. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
PS: The DGB-550BK is better
SOURCE: I have a cuisinart with brew and grind coffee
Stuck? how stuck can it be when it is supposed to be removable? Try turn ing it,
SOURCE: Saeco Incanto S-Class Sirius coffee machine not sensing beans.
I have had the same problem the only way I could get it to brew would to use the program quantity feature every time. I was going to take it in today and decided to restore the factory settings and now its working like it should. This seems to be a circuit board issue Ouch! I have another issue with the steam, if I take the knob off it works if I don't it doesn't glad I bought a 2K model GRRRRR!
SOURCE: Krups Grind & Brew KM7000
The grinder is activated by a microswitch inside the grinder housing. Under normal circumstances, the microswitch gets closed by swinging the filter lid 'away' from the filter (i.e. into the grind position).
Unfortunately, sometimes the microswitch works itself loose, and no longer closes when you swing the filter lid open, so the grinder doesn't come on, since it thinks the filter lid is still in the way.
This seems to be a common problem with this rig. I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected]
