Lexmark C500n Laser Printer Logo
Posted on Oct 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CHECK TONER MC - Lexmark C500n Laser Printer
Anonymous
Level 3:
Genius:
  • Master 1,456 Answers
  • Posted on Oct 23, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1456
Questions
0
Helped
475820
Points
4013
Hello
This means your ink level is low but you can confirm this by doing the following;
.The Lexmark C500n uses powdered ink, called toner, like other laser printers. The printer creates a magnetic charge on the paper as it passes through the machine, forming text and images on the page. The printer then applies pressure and heat to the paper, fusing the powdered ink to the page so it will not smudge or run. At any time, you can check the amount of ink left in the printer's toner cartridge by printing a status page. This page will also show a tally of the number of pages printed by the machine, among other information.
Turn on the printer and let it warm up. Ensure the light next to "Ready" illuminates.
Press the "Go" button, or the button with the icon of the hand pressing a button. Use the arrow button on the printer's control panel to highlight "Test Menu," then press the button with the check mark.
Press the arrow button until you highlight "Status Page" on the printer's display panel. Wait as the printer generates a status page.
Retrieve the status page from the printer's output tray.
By doing this you will know the level of your toner.
When turn on machine write 'call service' so I hold 0+8 and 690 but it write report machine waiting then it not work?
U can try this press 0+8 simultaneously put on ur mc then ur mc display will show (add) type 400 start if mc show 5 clear put 0 intrept
Change MC toner
magenta toner cartridge (RED ONE)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I ran out of toner so I ordered a new black toner cartridge. It arrived today. I can not find the directions to replace it in the literature I have for the MC 2400 W. How do you replace the toner...
push rotate button until it get to black, pull the handle on the front of the toner and release/remove the old one. Line pegs up with slots and lock in place. close all compartment doors.
2answers
LBP 5970 --16 PREP.Y TNR
Hi!
Y toner is your yellow toner that needs to be replaced!!C is cyan,M is magenta and BK is black!!
Enjoy!!
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
2helpful
C-OF34 error code?
this error code means there is a low toner to developer ratio in the yellow developer the common causes for this problem is the pwb-mc board needs to be replaced or the yellow toner motor needs to be replaced or or the toner motor one-way gear has failed to reset the error code leave the machine on and open then close the front door if the error code comes back check and or replaced parts listed above.
1helpful
Bizhub C350 gives error code C-OF36 while making duplex copies . M achine will produce half a dozen copies, then return the error code.
that code means low toner density in the black developer unit so you either have a failed pwb mc board or a failed black toner motor
2answers
When the red light is on, what does that mean? It not printing!
check if their is still paper in the printer cassette or check if their is paper jam
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Canon lbp5960 error 16 prep mc toner
That's a low toner message for the Magenta & Cyan cartridges.
-Jim
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
