If you look at the bottom of the device usually u can find it on a sticker at the back, or you may chose to access control panel and try viewing from the system if you are running xp, am sure it is a similar route with vista or windows 7. good luck
Press F8 Just after you press the power button. a window will open select safe-mode use the arrow keys to select and hit enter .then safely restore the computer using system restore.or uninstall the graphics Driver from control panel.the drivers that you were going to install was digitally signed? this thing usually happens when you install an unsigned driver . click her to know hot to use system restore
you need the wacom touch screen driver, just go to wacom .com and all i did was download and installed the driver, i run win xp , not tablet version, and after the driver ws installed the table an pen worked 100%,
i had the same problem, then i look for toshiba viturle sound wont work so try to install soundmax AC'97, coz R10 used Intel 82801DBM board. just search for intel 82801DBM Drivers
The Satellite R10-S802TD doesn't have built in bluetooth device, however it's bluetooth compatible. any external bluetooth adapter will work. Toshiba recommends PA3370U-1BTM Toshiba Bluetooth SD Card V1.2 or PA3405U-1BTM Toshiba Bluetooth USB adapter as indicated you product's spec sheet. Please post if you need further assistance.
