Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
How do i connect the power cord to my cabrio dryer?
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Oct 28, 2010
6ya staff
SOURCE:
Whirlpool cabrio gas dryer keeps heating to the point of melting power cord.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Dryer.
Mar 17, 2017 | Whirlpool Dryers
Have a whirlpool cabrio dryer model number WED8500DW1 the screen just flashed very fast like the touch screen is broken is there a way to reset the dryer
You can download the manual for your dryer at the website below. It's 40 pages. It may contain reset instructions, I don't know.
Whirlpool WED8500DW Manual
Nov 17, 2016 | Whirlpool Dryers
Whirlpool electric cabrio dryer no power
change relay board top board under lid upside down left side of dryer
Nov 30, 2013 | Dryers
My whirlpool cabrio dryer has an error code "PF" What does this mean?
The PF error code means power failure. IF the dryer was running and the power went off that display would show. I am assuming your power didtn go off yet the dryer trought it did, so the things to check is for a good tight connection on the power cord at the back of the dryer, a possible loose connection on the wall outlet where the cord plugs into ,or even a weak circuit breaker.
Good luck,
Gene
Aug 13, 2011 | Dryers
I am getting a cabrio dryer today and i have a regular home outlet where my last dryer was, can i use the old cord on the new dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Whirlpool Dryers
Mywhirlpool cabrio WED6200Sw0 dryer doesn't turn
whirlpool cabrio infamous for blowing out control boards check with a multimeter to see if you have power going into the machine and trace the lead power wire to the control board most likely it is your main control board hope this helps
Jul 14, 2010 | Whirlpool WED6200S Electric Dryer
3 prong to 4 prong where do you go with the ground wires
The following link explains how to correctly install a power cord on your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link thoroughly and let me know if you have any questions. I hope you find this helpful.
Jul 08, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
New Whirpool Cabrio dryer won't start
The center wire on the cord connects to the center connection on the wiring terminal on the dryer. That is the ground.
May 18, 2009 | Whirlpool Dryers
II HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL.
Your issue is as follows;
"iI HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL."
A 3 prong cord should be wired as follows:
1. 1 end of cord connects to 1 outside terminal.
2. The other end of the cord connects to the remaiing outside terminal.
3. The center wire connects to the center terminal.
4. A separate ground wire should be attached from the dryer chassis, then to a metal cold water line, or an exterior grounding rod.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 17, 2008 | Whirlpool Dryers
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
719 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
