SOURCE: GE JVM1660 1000 Watts Microwave Oven
This is a problem with the control panel assembly, which we repair nationwide for $39.95. This is usually caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. If you decide to send it for service, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: Spacemaker XL Microwave Oven MODEL JVM1640 Help
please check control circuitand related circuit and wiring mains fuse and related circuit
SOURCE: upon startup, on high power, trips the circuit
If it went dead almost
immediately after pressing the Start pad, that's usually a shorted
high-voltage capacitor. See here.
If it went dead
several seconds after pressing the Start pad, that's usually a
failing
high-voltage transformer. See here.
If
it goes dead or blows the breaker (or GFI) when you plug it in or open
or close
the door, then there's a problem with a door switch or door switch
mount. See this file.
You can find
exploded views and order parts by entering your model number (from the tag in or on the unit) at the Sears
parts site.
BUT once you have the
part number from the Sears site, you can often get the parts
cheaper here.
There
should also be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
Testimonial: "This was great, MicrowaveSvc gets an A+. Thanks very much."
SOURCE: it jus stopped working as soon as i set the timer
in most cases the reason for microwaves shutting down without warning is the fuse. in some cases the fuse will fail at its own fault. to test the fault we would do a tollerence test on the unit. but the best way for you to test it is to replace the ceramic fuse with another of the same value. if the unit works then its a faulty fuse. if the unit blows the fuse then the unit has a fault in the power supply that needs to be repaired by a service tech.
SOURCE: Black LG microwave oven, fail light bulb inside, I
The oven lamp is accessible when the whole outside cover of the oven is removed. The lamps these days are a special bulb and would be available from a TV repair place or a appliance repair centre.Take the old lamp in with you to pbtain the correct part.
