Assuming it is not actually full, this might mean the card is incompatible with the camera (too high a capacity) or it might mean it needs formatting. Usually a camera will say if it needs formatting, so I would check the camera specs to see whether you have a memory size it can handle. SDHC cards are not backwards compatible with SD cards.
SOURCE: Camera saying memory full to a brand new memory card.
You may have a defective memory card. Have you tried it in a different device? Do you have a card reader on your printer or computer? If so, try inserting the card and see if your computer can read the card, and write files to the card.
SOURCE: how to correctly install new memory card
you need to set the camera to use the card and not the internal memeory
SOURCE: The camera doesn't accept new memory card put into the camera
Sorry that this answer is far too late to be of use to you, but it may help others searching for advice with the same fault. I only stumbled across your unanswered question by accident.
8GB is an SDHC card. Your camera was designed to use the earlier SD cards instead with a maximum 1GB capacity.
SOURCE: i have a samsung nv3
It may be telling you that the internal memory is full. You must get rid of anything in there. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your new card and do the "format" thing again.
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
Note:
