SOURCE: bose companion 3 series 2 multi media speaker system
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, the 14 seconds interval is significant. This is indicative that whatever fault it is, it is coupled to a time-based circuitry. The time-based circuitry need not be complicated. it can actually be a simple resistor/capacitor network. The capacitor takes a certain amount of time to charge and then discharge (14 seconds, 'whoomp'). Having said this, then the foremost suspect would be an electrolytic capacitor, probably low value (1~4.7uF), probably a coupler/decoupler. Of course the capacitor serving other functions could very well be the culprit as well.
Corrective measure would entail, identifying/determining which capacitor and replacement. Tedious as it may sound, each capacitor would then have to be tested for capacitance and leakage out of circuit or at least 1 leg un-soldered.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful would
be detrimental to my status. Should this solution not address your
concern, it would be appreciated if you could just not rate it at all. Cheers.
SOURCE: Where Can I purchase a bose companion 5 control pod?
you have to call customer service at 1-800-367-4008.Run about $35.
For the broken cable, have you tried to fabricate a new cable for it?
SOURCE: Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
