Sony Cyber-shot  DSC-T10 Digital Camera Logo
I have a Sony HDR-HC7E handycam and it came up with the same error message. E:62:10. I was taping (it uses a digital tape) and it shuddered and started going silly. I can still get it to work and record most of the time but the flashing NEVER stops. I don't want to hit it as so many people suggest
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Jan 22, 2008
SOURCE: Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Anonymous
  • 4402 Answers
  • Posted on Jan 28, 2008
SOURCE: Sony Handycam DCR-IP7E Micro MV Digital Camcord
Anonymous
  • 10594 Answers
  • Posted on Feb 26, 2009
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Anonymous
  • 477 Answers
  • Posted on May 25, 2009
SOURCE: Flash won't work and flash setting cannot be changed from menu
This is eather caused by a bad flash circuit or a bad mainboad. Repair cost around 65.00 to 75.00 to repair.
Anonymous
  • 248 Answers
  • Posted on Jul 06, 2009
SOURCE: error message E 91 01
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
1helpful
Hi I've connected a firewire cable between the handycam and my new iMac. iMovie/iMac doesn't recognise the connection. Are there settings on the Handycam that need to be made for transfer to the iMac?
No need to change any settings it will auto connected.Check your cable may be its faulty. Try other think to attached your iMC.If still not working then You Firwire driver not instal.
1helpful
Blown Sony HDR-HC7E fuse or board?
There are internal fuses yes, but they are surface mounted ones and not a DIY repair. There are protection diodes internally as well. If the adapter was not the correct one, it is possible that it popped the diodes and fuse.
You can buy the service manual from Sony directly for a cost.
Hope this helps,
Dan
1helpful
What is the best way to delete all taping from my mini dv's
You can use a powerful magnet swipe it up against the side of the tape several times or you can just tape over them again or you can put the lens cap on the camera and press record
Doesn't play or record tapes. Get a C.30.41 error. Will load tape. Tried resetting.
dear
u need to rate me for that ..ok dude....
actuallythis error is related to Head assy. i.e, the (head)drum motor is not completing its fg in proper time. try to use cleaning tape 1 st and then play back your normal tape.
if the problem persists then u need to go to the near by service center as they will clean the head assy. manually.
5helpful
3answers
HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
1helpful
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Cant record
C32 error codes are usually cassette or tape transport related. Can you eject the tape? Try inserting a new tape to see if the fault is with the tape itself.
If this doesn't work, I suggest that you take your camera to a service centre.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
