If it simply does not work at all, the circuit board is probably damaged. This is not repairable and you will need to buy a replacement. You will find a new clean and charge base at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sometimes the connector in the "neck" becomes faulty. You can try pressing down on it and see if you get a connection. If it does, then you can obtain a replacement part on-line (just the neck/tower part of the cleaner). Also, check eBay for used cleaners that are functional. This model uses the same cleaner as various other models in the 7000 series. You could get one at a fraction of the new cost.
