SOURCE: Devise reads no disc when disc is inserted
there is a flat white strip that is connected to the body of the lens replace it if that does not remedy the problem replace the lens.good luck
SOURCE: COBY TFDVD5605 Portable DVD Player repair tips
all potable dvd player work on 9V through cig lighter in your car adopters comes in three diffrent sizes.
SOURCE: will not turn on
I have the same problem. It worked fine for a while, then I could not even turn it on. I opened the case, and the fuse looks fine. I have no clue what the problem could be. When I turn the power on I head a click sound. However, there is no indication on the LED. The bay won't open/close and it does not respond at all. Almost like a corpse.
SOURCE: my coby portable dvd player keeps saying wrong disc
You may need to clean the laser in the unit. You can purchase a cleaning disk at Radio Shack or Best Buy. They are normally less than $20.
SOURCE: dvd player says loading then wrong disc
If it is disc made with a computer, you may need to convert the format to one that the DVD player is compatible with so it will recognize the disc contents.
