2007 Jaguar S-Type 3.0 Sedan Logo
Posted on Oct 22, 2010
How do install low beam headlamps on 07 s-type
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
1928
Points
19
Sony Vaio VGN-FZ38M battery
Type: Li-ion
Capacity: 5200 mAh, 8800 mAh, 10400 mAh,
Volt: 11.1 V
Size: 209.90 x 47.50 x 20.40 mm
Color: Silver
$ 89.33
http://www.daily-battery.com/sony-vgn-fz38m-battery.htm
1 Related Answer
Anonymous
  • 119 Answers
  • Posted on Jan 18, 2009
SOURCE: low beam headlamps not working on my 2004 armada
Did you check in the engine compartment.
If you go to autozone or advanced auto parts you can get a book for the car for about 15 bucks
2answers
Bright lights wont shut off on my 2004 chevy malibu
Bright lights wont shut off ? Assume you mean high beams ? Reading how they work might thing high beam relay has stuck contacts inside .
Headlamps
The headlamps may be turned ON 2 different ways. First, when the driver places the headlamp switch in the HEADLAMP position, for normal operation. Second, with the headlamp switch placed in the AUTO position, for automatic lamp control (ALC). During ALC, the headlamps will be OFF in daylight conditions, or low beam operation in low light conditions. Battery positive voltage is supplied to the low beam relay and the high beam relay in the underhood fuse block. When low beam headlamps are requested, the body control module (BCM) supplies ground to the coil side of the low beam relay. This activates the relay and the relay supplies voltage to the left hand low beam headlamp through the LH LOW BEAM fuse and to the right hand low beam headlamp through the RH LOW BEAM fuse. Ground for the left hand low beam headlamp is provided at G101. Ground for the right hand low beam headlamp is provided at G102. When high beam headlamps are requested, the body control module (BCM) supplies ground to the coil side of the high beam relay. This activates the relay and the relay supplies voltage to the left hand high beam headlamp through the LH HIGH BEAM fuse and to the right hand high beam headlamp through the RH HIGH BEAM fuse. Ground for the left hand high beam headlamp is provided at G101. Ground for the right hand high beam headlamp is provided at G102.
2006 hummer h3 headlights wont turn off!
Ive changed the relay and the headlight switch on the dash .. still wont turn off headlights ? Just changing parts won't fix it , need to test . Hooking up a professional scan tool , one that can read codes in the BCM - body control module is the way to start to find the problem . Then familiarize yourself with how they work.
Headlamps
Major components of this system are the body control module (BCM), headlamp relay, beam select relay, ambient light sensor, headlamp and panel dimmer switch, turn signal/multifunction switch, park brake switch, and the low and high beam headlamps.
The headlamps may be turned ON in 2 different ways. First, when the driver places the headlamp switch in the ON position, normal operation occurs. Second, when the headlamp switch is placed in the AUTO position, automatic lamp control (ALC) operation occurs. During ALC control, the headlamps will be OFF in daylight conditions or in low/high beam operation in low light conditions.
The headlamp relay receives battery positive voltage directly from the battery. The BCM supplies a ground signal to the headlamp relay for normal headlight operation. The BCM also supplies voltage to the beam select relay coil for high beam headlight operation. When the driver places the headlamp switch in the ON position and the dimmer switch is in the low beam position, the headlamp relay supplies current flow through the left and right low beam headlamp fuses to both low and high beam headlamps. Both low beam headlights are grounded through the beam select relay. When activated, the dimmer switch sends a ground signal to the BCM in the high beam position and a momentary ground signal in the flash-to-pass (FTP) position from G106. The BCM then energizes the beam select relay which switches the headlamp grounds from the low beam headlight bulbs to the high beam headlight bulbs illuminating the high beam headlights. With the headlights in the low beam position, the high beams may be momentarily turned ON or flashed by activating the FTP portion of the switch.
The instrument panel cluster (IPC) illuminates the high beam indicator when the BCM detects that the high beams are requested. The IPC receives a class 2 message from the BCM requesting illumination.
The Headlamps On at Exit and Perimeter Lighting modes can be adjusted using the steering wheel controls to select the function as displayed in the driver information center (DIC). The Headlamps On at Exit selection will allow the driver to customize the period of time that the headlamps remain illuminated upon exiting the vehicle. This period can be adjusted from 0-180 seconds. The Perimeter Lighting feature allows the driver to select if they want the headlamps and backup lamps to illuminate when the door UNLOCK button on the key fob is activated. This feature can be turned ON or OFF by using the DIC steering wheel control buttons.
DTC B2575 Headlamp Control Circuit
Circuit Description
When the body control module (BCM) senses a request for headlamp or daytime running lamp (DRL) illumination, the BCM sends a ground signal to the headlamp relay through the low beam headlamp relay control circuit. The headlamp relay will illuminate the low beam headlamps.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, command the headlamps ON and OFF.
Does the headlamp relay turn ON and OFF with each command?
Do you know what bi-directional control means ? Need a professional scan tool to do these type of test .
DTC B2602: Daytime Running Lamp Control Circuit Low or Open
DTC B2603: Daytime Running Lamp Control Circuit High
Without this type of info. from service repair manual an using a scan tool your missing the big picture .
I drive a 2005 SAAB 9-7X the low beam light had gone out and I replaced them and I still have no low beam
Did you test the low beam electrical circuit using a volt meter ? Look at a wiring diagram to see what all is involved in turning the lights on ? Do you know how to test electrical circuits ?
Also reading service repair manual about the head lamps opp. would be a good thing to do .
Headlamps
The major common components of this system are the body control module (BCM), ambient light sensor, multifunction switch, park brake switch, and the headlamps.
The headlamps may be turned on in 2 different ways. First, when the driver places the headlamp switch in the HEADLAMP position, normal operation occurs. Second, with the headlamp switch is placed in the AUTO position, automatic lamp control (ALC) occurs. During ALC control, the headlamps will be in daytime running lamp (DRL) operation in daylight conditions, or low beam operation in low light conditions.
The low beam relay and high beam relay receive battery positive voltage directly from the battery through the HDM and COILS fuses in the underhood fuse block. The BCM supplies a ground signal to the low beam relay coil for automatic headlamp control and normal headlamp operation. The BCM also supplies ground to the high beam relay coil for high beam headlamp operation. When the driver places the headlamp switch in the HEADLAMP position and the dimmer switch is in the low beam position, the low beam relay energizes sending current flow through the left and right low beam headlamp fuses to both low beam headlamps. The dimmer switch sends a ground signal to the BCM in the high beam position and a momentary ground signal in the flash-to-Pass (FTP) position from G102 to deactivate the low beam headlights and activate the high beam headlights. With the headlights in the low beam position, the high beams may be momentarily turned on or flashed by activating the FTP portion of the switch.
Low Beams - Standard
The standard low beam headlamps receive voltage from the headlamp driver module located in the underhood fuse block. The body control module (BCM) controls the headlamp driver module with the headlamp low beam relay control circuit. Low beam control is determined by a signal on the headlamp dimmer switch signal circuit from the multifunction switch. When the headlamps are requested ON and the headlamp dimmer switch signal circuit is open, the BCM sends a pulse width modulated (PWM) ground signal though the headlamp low beam relay control circuit to the headlamp driver module which illuminates the low beam headlamps at a 100 percent intensity level. The right and left low beam circuits are independent and are fused separately in the underhood fuse block. The LOW HDLP-RT 10A fuse supplies voltage to the right low beam headlamp and the LOW HDLP-LT 10A fuse supplies voltage to the left low beam headlamp. The right and left headlamps are grounded at G103 and G107 respectively.
Your best bet mite be to have a qualified technician check it
1helpful
2011 HHR headlights not working. No high or low beam . Any ideas?
Do you know how to test electrical circuit's using a wiring diagram an a voltmeter ? Reading how the headlamps are suppose to work ,then testing is how to find the problem .
Headlamps
The headlamps may be turned ON 2 different ways. First, when the driver places the headlamp switch in the HEADLAMP position, for normal operation. Second, with the headlamp switch placed in the AUTO position, for automatic lamp control (ALC). During ALC, the headlamps will be OFF in daylight conditions, or low beam operation in low light conditions. Battery positive voltage is supplied to the low beam relay and the high beam relay in the underhood fuse block. When low beam headlamps are requested, the body control module (BCM) supplies ground to the coil side of the low beam relay. This activates the relay and the relay supplies voltage to the left hand low beam headlamp through the LH LOW BEAM fuse and to the right hand low beam headlamp through the RH LOW BEAM fuse. Ground for the left hand low beam headlamp is provided at G101. Ground for the right hand low beam headlamp is provided at G102. When high beam headlamps are requested, the BCM supplies ground to the coil side of the high beam relay. This activates the relay and the relay supplies voltage to the left hand high beam headlamp through the LH HIGH BEAM fuse and to the right hand high beam headlamp through the RH HIGH BEAM fuse. Ground for the left hand high beam headlamp is provided at G101. Ground for the right hand high beam headlamp is provided at G102.
Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. Year , make , model an engine . Under system click on lighting , then under subsystem click on headlamps . Click the search button ,then the blue link .
Video's on youtube on electrical testing
2answers
Adjusting headlamp
There are two basic types of headlight system and both are available in both two and four headlamp arrangements.
The original (and still the best in my opinion) is the British American type that is adjusted for aim on high beam.
Almost universally adopted today is the asymmetric beam type headlamp system that provides a pattern with a flat top on low beam and must be adjusted on low beam for accurate aim, except where there are four lamps - the inner driving lamps only light on high beam and must be adjusted thus...
1helpful
3answers
Low beam headlights do not work 2010 chevy impala high beams work as do daytime running lights low beams do not work on either automatic mode or manual mode
The headlamps are controlled by the BCM - body control module , do you know what that is ? The headlamp switch is a input to the BCM ,the BCM energizes relays to turn on the headlmps , low beam relay , high beam relay , DRL relay . These relay's are PCB - printed circuit board relay's ( non - serviceable ) If found to be bad the whole under hood fuse box would need to be replaced .
Low Beam Headlamp Operation
The low beam headlamps may be turned ON in 3 different ways:
ā€¢ When the headlamp switch in the HEAD position for normal operations
ā€¢ When the headlamp switch is in the AUTO position, for automatic lamp control (ALC)
ā€¢ When the headlamp switch is placed in the AUTO position, with the windshield wipers ON in daylight conditions, after a 6 second delay
Battery voltage is applied at all times to the coil and switch sides of the LOW BEAM PCB Relay located in the underhood fuse block. When the headlamp switch is placed in the HEAD position, ground from G202 is applied through headlamps ON switch signal circuit to the body control module (BCM), signaling the headlamps ON request. In response to this signal, the BCM applies ground through the headlamp low beam relay control circuit energizing the low beam relay. With the relay energized, battery voltage is applied through the switch side of the relay, the left and right low beam fuses, and the low beam supply voltage circuits illuminating the low beam headlamps. Ground for the left headlamp is provided at G101 and the right headlamp at G100.
Do you know what B codes are ? BCM - DTC'S - diagnostic trouble codes , need a factory scanner or professional one to view these codes , not autozone or advance etc....Having a qualified repair shop check your vehicle would be your best bet.
DTC B2575 00: Headlamp Control Circuit
Circuit/System Description
The vehicle headlamps are controlled by the body control module (BCM) based on inputs from the headlamp switch and the turn signal/multifunction switch. The headlamp switch has four positions: Off, Auto, Park, and Headlamps. The default headlamp switch position is Auto, in which the BCM uses the ambient light sensor to determine when headlamps are needed. The Off portion of the headlamp switch is a momentary switch which overrides the automatic headlamps and will turn off the vehicle headlamps. When in the Off position, the headlamp switch grounds the headlamp switch headlamps off signal circuit, prompting the BCM to turn off the headlamps. The Park position of the headlamp switch will only illuminate the vehicle parking lamps. The Headlamp position of the headlamp switch will illuminate both the parking lamps, as well has the headlamps. With the headlamp switch in the Headlamp position, the headlamp switch headlamps on signal circuit is grounded, prompting the BCM to turn on the headlamps, regardless of other factors such as ambient light.
The headlamp high beams are controlled through the flash to pass switch and the headlamp dimmer switch, both located in the turn signal/multifunction switch. The flash to pass switch is a momentary type switch, designed to illuminate the high beams as long as the switch is held. With the switch closed, the flash to pass switch signal circuit is grounded, prompting the BCM to turn on the high beam lamps. The headlamp dimmer switch allows the operator to select between full time high or low beam operation. Unlike the flash to pass switch, it is not a momentary switch. When the headlamp dimmer switch is in the high beam position, the headlamp dimmer switch high beam signal circuit is grounded. This prompts the BCM to turn on the high beam lamps.
The BCM controls the headlamps based on the inputs explained above. When a low beam request is received, the BCM grounds the headlamp low beam relay control circuit. This energizes the coil in the LOW BEAM PCB relay, causing the relay switch to close. This then applies B+ to both low beam headlamps through the LT LO BEAM and RT LO BEAM fuses, illuminating the low beam headlamps. When a high beam request is received, the BCM grounds the headlamp high beam relay control circuit. This energizes the coil in the HIGH BEAM PCB relay, causing the relay switch to close. This then applies B+ to both high beam headlamps through the LT HI BEAM and RT HI BEAM fuses, illuminating the high beam headlamps
2answers
2008 Saturn aura wont start after trying to put rt.low lowbeam replacement
On the inside of the lid is a diagram .
17helpful
2answers
How do I replace the headlight bulb on a 2005 Town Car?
1. Remove the three pin-type retainers, two screws and the radiator defector.
2. Remove the 4 bolts securing the headlamp assembly and remove headlamp assembly.
- Disconnect electrical connector
3. Remove the 3 hex-head bolts and 2 torx-head screws and remove headlamp protective cover.
4. *****Standard low-beam bulb*****
Disconnect the connector from the bulb and remove the low beam bulb.
5. *****HID low beam bulb*****
Release the spring tabs and remove the HID low beam bulb
6. *****High beam bulb*****
Disconnect the electrical connector and remove the high beam bulb.
Reverse order to install
How do i remove bulb from socket for day time running light on 2002 avalanche
  1. Open the hood.
  2. Remove the park/turn signal lamp assembly.
  3. Remove the headlamp retainer pins.
  4. Pull out the headlamp assembly in order to access the electrical connector.
  5. Disconnect the electrical connector.
  6. Remove the bulb from the headlamp assembly by twisting the bulb counterclockwise.
INSTALLATION PROCEDURE
IMPORTANT:
  • Replace a high beam bulb with another high beam bulb. The high beam bulb has a red gasket.
  • Replace a low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a yellow gasket at the base.
  1. Install the new bulb to the headlamp assembly by twisting the bulb clockwise in order to lock in place.
  2. Connect the electrical connector to the bulb.
  3. Install the headlamp assembly.
  4. Install the headlamp retainer pins.
  5. Rotate and lock the pins in place.
  6. Install the park/turn signal lamp assembly.
  7. Inspect the operation.
4helpful
How to change front headlamp bulb? Low beam
  1. Open the hood.
  2. Remove Grille.
  3. Remove the 2 retainers on back of headlamp assembly and remove the headlamp from the sheet metal panel.
  4. Remove the access cover from the rear of the headlamp.
  5. Disconnect the electrical connector from the socket.
  6. Rotate the bulb and socket counter clockwise in order to remove the bulb and socket from the housing.
  7. Disconnect the electrical connector from the socket.
  8. Remove the bulb and socket from the headlamp.
Installation Procedure Important: • Replace a high beam bulb with another high beam bulb. The high beam bulb has a black socket. • Replace a low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a grey socket.
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
