Do not know code to get child lock UNLOCKED. I would like to watch pg14 and older type shows.
My TV is show " child lock please unlock" and i repeatedly attempted and ther is no feasibility .
and i want help please help mee
Hi to you
I have a problem my son was playing with the remote for my sharp television it's a (29FL91M ) but I switch off the tv and don't know the code he entered no matter what i press I just can't get the tv to show any thing it keeps asking for the child lock code which i don't know what can i do
0711 twice, then the new code - double-check the onwer's manual, however, sometimes 0,0,0,0 and 1,2,3,4 work; 0711 is the Magnavox universal
I thought of a better idea:
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- repeatedly until
SET is highlighted.
3 Press CH+ or CH- to highlight CHILD
LOCK.
4 Press VOL+ or VOL- to choose ON or
OFF.
Choose ON to disable all the buttons on
the front of the TV. CHILD LOCK ON
will appear briefly on the TV screen each
time you press a button on the front of
the TV.
You can still operate the TV with the
remote control.You can still use the
POWER button on the front of the TV,
but only to turn off the TV (not on).
Set CHILD LOCK to OFF to cancel this
feature so you can use the buttons on
the front of the TV again.
5 Press TV/AV/EXIT to remove the
menu from the screen.
I have a universal remote and can get into the main menu, but can not move to a different line on the menu.
I have startrek tv model no jolly 1453 not able to remove chile lock
pls help
rgd's
pallavi
How can i watch on my fav. tv show if the tv is lock only on one channel??? someone know how to help me?? please help me.. just cnd to me on facebook how to help me guy's... thanks a lot.. this is my email... [email protected] .. thanks a lots.....
My grandson has locked the programes on our Philips Television ,the Bloccato is appearing on the screen ,how can we override this problem.
Instructions
Locate
the manual for your television. Though slightly embarrassing, accidentally
turning on the child lock to a TV is a common problem. The section In the
manual about how to set the child lock feature will also explain how to unlock
it.
Try
a few "universal methods" for unlocking the child lock. Some
televisions have a universal code built in for disabling the child lock --no
matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Locate
it.
Try
child lock code.
I want to thank you guts VERY VERY much!!!!!!!!!!! the 0711 WORKED!!! Sorry it took awhile for me to get back to you. You are very much appreciated. Thank you again
I open the tv this morning and it came out black and there red writing saying "child lock" please unlock. How do you unlock a magnavox tv?
yes
I switched on the tv this morning and it came out black and there a red box and writing saying "child lock" please unlock. How do you unlock an imperial tv?
my tV MAXWELL Is locket chiled and i don't have remot how i can locket off
my tv has the child lock on it and i do not have a remote so what should i do
i have nobel televesion model #DN 5144737 when its power the blue screen shows lock not shows child lock and remote control only works and it is not removed from remote....
