My HP PSC 1410 has blinking light indicating a paper jam or incorrect paper size selected, neither of which seems to be the case.
It can't seem to get the paper going. Maybe a loose or misaligned gear?
Suggestions?
To be able to understand the problem, you should give extra info about the lights. Please find the information below about the status lights that provide information about error conditions of your printer.But first you need to install the driver for your operating system. The drivers are necessary to print documents and scan images. These drivers must be installed to use the print and scan features.
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following: 1 Verify that the front-panel overlay is attached to the HP PSC. 2 Turn your HP PSC off and on by disconnecting the power cord and reconnecting. Problem 1:“ON” light is on, “check paper” light is blinking and “check print cartridge light” is off .
Explanation 1:The paper tray is empty, the HP psc has a paper jam, or the paper size setting and paper in paper tray are not the same. Solution 1: • Load paper, or remove thepaper jam. • Change paper in paper tray to correct size. • Change paper size on the computer software. Then press On/ Resume to continue. NOT : PLS SEE THE NEXT MESSAGE. CONTINUED AS THE COMMENTS BELOW:
reason of all led check all step by step
1. cartridge short or fail
2. encoder strip not working
3. paper sensor not working
4. carrige block data cable brake
5. carriage block pcb fail
6. main pcb fail
There is an online guide to clearing paper & envelope jams on the HP website below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=441115&rule=27514
Please update the question & let us know if the information given was useful to you - Good Luck!
