Canon MultiPASS MP730 All-In-One InkJet Printer Logo
Posted on Oct 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keeps displaying wrong cartridge and wont print
Anonymous
Level 2:
President:
  • Expert 261 Answers
  • Posted on Oct 21, 2010
Anonymous
Expert
Level 2:
President:
Answers
261
Questions
Helped
71645
Points
897
HI check the code of color tank and replace it correctly if does not work clean the flat that stick on tank
1 Related Answer
Anonymous
  • 60 Answers
  • Posted on Feb 15, 2008
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Keeps saying my colour cartridge is missing
Problem
Wrong cartridge; Left cartridge incorrect; Right cartridge incorrect; Left cartridge missing; Right cartridge missing; Error 1205; Error 1206; Cartridge error; Cartridge incorrect; Cartridge missing
Environment
Microsoft Windows XP; Microsoft Windows XP Professional x64 Edition; Microsoft Windows 2000; Microsoft Windows Vista
Solution
Explanation
An 'incorrect cartridge' or 'missing cartridge' error can be displayed if:
    • The wrong cartridge is installed, or
    • The cartridge is not installed properly, or
    • The cartridge is missing.
What to do
X4850
http://support.lexmark.com/index?page=content&id=SO4738&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4875&locale=EN&userlocale=EN_US
Said that cartridge was empty after changing cartridge,got that cleared and now it will not receive a fax. What do I need to do
Your faxes are probably stored in memory. They automatically print when the a) cartridge is installed properly full, b) fax has paper, c) there is no paper jam.
There also may be a "Print Hold" function activated.
1. Press <print hold> [RCV DATA PRINT] will display.
2. Press "Right Arrow" on the <start/memory> button.
3. Enter 4-digit Print Hold code.
4. Press <start/memory>. Printing will begin. If the wrong code is entered [WRONG CODE] will display. Go back to step 3 and start again. Once you've entered the wrong code 3 times, you will return to your standby display.
My lexmark keeps displaying wrong cartridge on right side and it's the right one anybody have an idea whats wrong
Hi, it might be the cartridges are not seated well in the carrier or just needs cleaning. Try this if it helps. Remove the cartridges from the printer. Close the cover. Unplug the printer from the power source for now. Grab a damp paper towel and place it on the table. Have one cartridge and set it on the towel with the nozzle facing down. Draw about 2-3 lines in one direction to wipe clean the nozzles. Do the same to the other cartridge. Plug the power for the printer. When printer's ready, load the cartridges back in. Let it print the alignment page. After printing, check if problem persists. Hope this resolves the problem. Good luck!
The printer keeps on displaying the usupported
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
It keeps giving the alert wrong cartridge and wont print.I installed for the 1st time ink power cartridge instead of canon's and it won't do nothing........... these cartridge are half price but look...
Wrong cartridge refers to the printhead and not the inks. This machine, when the printhead goes bad gives that error. A new printhead is around $60.00 for that machine. QY6-0064-000.
What does the cartrige icon stand for in the hp deskjet 840c?
If the cartridge icon is being displayed and the printer wont print it means either the cartridge is installed incorrectly or you are out of ink.
1helpful
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Incorrect right cartridge
Ive tried removing the right cartridge so I can print in black, but now , once I refilled the black one, it wont even let me print black!! this is desperate; can anyone help?
7helpful
5answers
Display Says Wrong Cartridge
I went to the Canon website http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035 and typed "Wrong Cartridge" in the search portion for the MP730. It listed detailed instructions to remove all ink cartridges, raise the lever to the right on the carrier, and then remove / reseat the "carrier". After that I replaced all cartridges and printed the alignment page. All is working, now.
My printer wont print
same problem here. bought new ink cartridges, still no difference. Just the "E"
old marine
old marine
ZJ Limited
ZJ Limited
