Nokia 2690 Cell Phone Logo
Posted on Oct 21, 2010
My phone is nokia 2690,i forgot my memory card password and i need to unlock my memory card sso please tell me some idea to unlock
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1473
Points
79
My memory card is lock please unlock
  • nfrt_bh Mar 21, 2011
    THANK'S
Anonymous
Level 1:
New Friend:
  • Posted on Feb 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1473
Points
24
My memorycard is lock please unlock it
akshyakumar7
Level 1:
New Friend:
  • Posted on Aug 21, 2011
akshyakumar7
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1473
Points
TONY EDWARD
Level 1:
New Friend:
  • Posted on Mar 22, 2014
TONY EDWARD
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1473
Points
My memory card is locked pls unlock
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1892
Points
5helpful
We forgot my memory card password in nokia 2690 what i do
You have to these things to unlock your memory card
1. First Install FExplorer in your phone memory.
2. Got to drive C: , you will find a file called mmcstore
3. Send it to your pc directly and open it in notepad or rename the file.
4. At the end of the file you will find your password
tip
Unlocking SD Memory Card of Nokia 2690
Nokia 2690 is a mobile phone made by Nokia Corporation. Nokia 2690 have 25 MB internal memory, microSD memory card slot with hot swapable. Many user faces problem in unlocking the password of SD memory card. As the SD memory card contains valuable data like songs,images, files, etc. To protect the SD memory card from the unauthorize use, its is protected by secure password or lock code. Some time the password gets forgotten or it gets blocked technically resulting in faliure to unlock the SD memory card. To unlock the SD memory card password you need the utility called FE Explorer. After installing the FE Explorer in the phone, insert the card in to the phone but do not access it. After running the FE Explorer open the path C:system. There is a file called mmcstore. Rename the mmcstore file to mmcstore.txt. Transfer the mmcstore.txt to the pc or laptop and open it in notepad. After opening the file there is a password to unlock the SD memory card of Nokia 2690. Using FE Explorer we can remove the password of other micro SD memory card like Kingston, SanDisk, Verbatim.
Please download the software from the link provided below :
http://fexplorer.en.softonic.com/download/25347
Also visit the help link provided below :
http://www.mobiclue.com/recover-memory-card-password-from.html
27helpful
2answers
My hand set is nokia 2690. Once i set password on
Hello Mukerjee,
To unlock the memory card password of Nokia 2690 Cell Phone.
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file to unlock memory card password of Nokia 2690 Cell Phone.
Also visit :
5helpful
Nokia 2690, i forgot my memory card passwoard.
for unlocking to the nokia cellphone go to the settings next to the application [or] organisation right click in the memorycard option and select the delete password option enter the default password to remove the password from your memorycard..............
THANKS.
57helpful
3answers
I am using nokia 2690 i put password for my memory card but i forgot the password pls tell how to remove password for my memory card ......................
Man do one thing..connect ur cell with pc, copy all the required items on ur pc & then format the memory card .. Understood..dude
Sir my memory card has been locked and i forgot the password how can iunlock
Hi Reyaz
Welcome To Fixya
You should go to mobile repairing center to unlock the memory card password.for that center's staff will unlock your nokia 2690 memory card password with the help of memory card password unlocker software.For that that staff will keep that memory card to the unlocker device then after he will unlock it within 2 to 3 minutes.That's it.don't worry.it will help you.if this solution will help you then don't forget to vote me at least 3 to 4 thumbs.
thank you for using Fixya.
14helpful
2answers
I have forgot my nokia 2690 memory card password
hi friend,
i got the same problem on my nokia 2690.i forgot the memory card password.the most suitable solution for this problem is,you should first check out your memory card on card reader device either your memory card is working good or not.after checking if your card is fine till today,you should insert your memory card into memory card unlocker device like card reader.that device will remove your memory card lost password.now it works fine.
thank you
for joining Fixya.
9helpful
I forgot my nokia 2690 mobile memory card password
Sir i forgot the memory card password now it is insert any phones it will asking the password what will do. Now am useing nokia c1-01
155helpful
7answers
Nokia 2690 memory card password remove
Hi , Follow the following steps to unlock the memory card
  • To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
  • After finished downloading, install it to your mobile phone.
  • Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  • Run FExplorer and open the following location C:\system.
  • From the location C:\System, you will see a file named as mmcstore. Rename this file asmmcstore.txt.
  • Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  • When you finished the above steps, you will find the password of that file.
  • With this password u can open ur Memory card
For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
61helpful
My phone is nokia 2690 i have forgoten my memory card password pls help me
my phone is nokia 2690 & i forgett my memory card password tell me how to unlock pls
Aug 06, 2010 • Cell Phones
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
